How do i get the normal desktop with 0.18 image?
When I installed Raspberry Pi, i used the latest version with everthing in it, and I have a bar at the top for
all the items.
Now with this version, it seems to be like a windows 3.1 screen.. Is there a way to get the pretty desktop with all the apps in it somehow ?
I did an sudo app full upgrade but no difference.
Thank you
OctoPi comes without a GUI because it's meant to run OctoPrint as a server with a web front end. BTW: Windows is also a GUI, you mean DOS 3.1
At the end of the startup sequence is a hint how to install the desktop GUI.
See also here:
To quote the welcome message on the terminal:
This image comes without a desktop environment installed because it's not
required for running OctoPrint. If you want a desktop environment you can
install it via
    sudo /home/pi/scripts/install-desktop
Thank you.
I don't recall ever seeing that message.
It's installing some stuff now.
Thank you :smiley:
