Logitech C270 and WinBook UVC CAM
Cannot setup a second instance of webcam daemon.
I had it working by following this guide: https://www.makersmashup.com/post/outside-the-box-multiple-webcam-setup-with-octoprint
I had to redo everything and it seems now the structure has changed, the guide is no longer valid.
Pi 4, latest octopi .17.0
This is what I get when i start my second instance:
Starting up webcamDaemon...
cfg_file: /boot/octopi-cam2.txt
camera: auto
usb options: -r 1280x720 -f 30 -d /dev/video3
raspi options: -fps 10
http options: -w ./www -p 8081
Explicitly USB device: /dev/video3
Found video devices:
/dev/video0
/dev/video1
/dev/video10
/dev/video11
/dev/video12
/dev/video2
/dev/video3
config file='/boot/octopi-cam2.txt':USB device was set in options and found in devices, start MJPG-streamer with the configured USB video device: /dev/video3
<13>Dec 5 23:26:05 pi: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www -p 8081 -i input_uvc.so -r 1280x720 -f 30 -d /dev/video3
MJPG Streamer Version: git rev: 501f6362c5afddcfb41055f97ae484252c85c912
i: Using V4L2 device.: /dev/video3
i: Desired Resolution: 1280 x 720
i: Frames Per Second.: 30
i: Format............: JPEG
Unable to set format: 1196444237 res: 1280x720
i: init_VideoIn failed
Goodbye...
Also, when i list devices
bcm2835-codec-decode (platform:bcm2835-codec):
/dev/video10
/dev/video11
/dev/video12
UVC Camera (046d:0825) (usb-0000:01:00.0-1.1):
/dev/video0
/dev/video1
USB2.0 HD UVC AF Camera: USB2.0 (usb-0000:01:00.0-1.2):
/dev/video2
/dev/video3
I don't understand why each one has two identifiers. It wasn't like this on my previous setup. Also not sure what the top 3 are.
Any help appreciated, thanks.
