I can't install octoprint on Windows. Every time I try to install when I try to do step 5 of the toturial Setting up OctoPrint on Windows an error appears to me.
C:\WINDOWS\system32>cd C:\OctoPrint
C:\OctoPrint>virtualenv venv
fail
File "c:\python27\lib\site-packages\virtualenv\seed\embed\via_app_data\via_app_data.py", line 92, in _get
do_periodic_update=self.periodic_update,
File "c:\python27\lib\site-packages\virtualenv\seed\wheels\acquire.py", line 23, in get_wheel
wheel = from_bundle(distribution, version, for_py_version, search_dirs, app_data, do_periodic_update)
File "c:\python27\lib\site-packages\virtualenv\seed\wheels\bundle.py", line 20, in from_bundle
wheel = periodic_update(distribution, for_py_version, wheel, search_dirs, app_data, do_periodic_update)
File "c:\python27\lib\site-packages\virtualenv\seed\wheels\periodic_update.py", line 41, in periodic_update
handle_auto_update(distribution, for_py_version, wheel, search_dirs, app_data)
File "c:\python27\lib\site-packages\virtualenv\seed\wheels\periodic_update.py", line 67, in handle_auto_update
trigger_update(distribution, for_py_version, wheel, search_dirs, app_data, periodic=True)
File "c:\python27\lib\site-packages\virtualenv\seed\wheels\periodic_update.py", line 186, in trigger_update
.format(distribution, for_py_version, wheel_path, str(app_data), [str(p) for p in search_dirs], periodic),
UnicodeEncodeError: 'ascii' codec can't encode character u'\xe3' in position 11: ordinal not in range(128)
fail
fail
UnicodeDecodeError: 'ascii' codec can't decode byte 0xe3 in position 35: ordinal not in range(128)
C:\OctoPrint>
Don't know what to do. Can someone help please?
Complete Logs
