I keep getting a weird spike on the tool when my print starts
I keep getting this weird heat spike in the beginning of my print. The tool is set to 400 and then to 245 to heat up. I just happen, everything was working fine and when I started a new print it keep happening. I tried to fix my PID in hopes that would fix it, it did now. I tried an earlier print that I knew it worked and the same thing. I am not sure what is wrong. I have not change anything
I tried to Fix my PID, that did not
I tried to run it in safe mode and it worked fine
yes
Hello @Manny_Reyes !
If running in safe mode helps, you have to disable all 3rd party plugins and enable them on by one to find the culprit.
And what's about the systeminfo bundle?
It can give us a hint on the issuing plugin.
You're using a 200°C offset
Bildschirmfoto vom 2022-01-05 09-35-07
And if you didn't set that offset manually, it's coming from the 'Filament Manager' plugin most likely.
Thank you soo much!!! I really appreciate it. It seems like that was the problem. when I started to print I used a new filament and I did not notice that the plugin had that setting, It was my first time using this plugin.
