After installation on Raspberry Pi Zero W octoprint is not running and when trying to run manually it (serve, systeminfo etc...) gives. No log available since it is like it never run once.
Illegal instruction
Reflashed, reflashed, reflashed using a different imager, reflashed through different OS (mac vs windows).
Searched through the forum for similar problem, found this one (SSH is working fine, but the server is not running), tried its solution and not a chance: illegal instruction. Upgraded everything through apt-get, still Illegal instruction.
Yes, it doesn't run: Illegal instruction
See above
Impossible since it gives Illegal instruction when trying to run System Information dialog
I've got a camera on the camera port it works, i can stream it over LAN. I installed everything with OctoPi 1.1.0.
Octoprint version: 1.11.2
