I have been trying for days to reinstall Octoprint on my Raspberry Pi Zero W, but I CANNOT get it to work.... I know it is not recommended to run Optoprint on this device type, but is has been working flawlessly on my previous internet connection. I can access through SSH, no logs file exists, and the suggested command >>ps -ef | grep -i octoprint | grep -i python<< returns nothing. If I understand it correctly, this means, that the program is not running?
I have multiplied times encountered the Illegal Intrsuction error while troubleshooting, and I am not sure what it means... SO frustrating - hope you can help me
Reflashed, reflashed, reflashed using a different imager, reflashed through different OS (mac vs windows). Fiddled with the DNS (am not sure, I understand that though) - I can ping google.com just fine, so there is internet connection.
Yes, or no, it returns the Illegal Instruction error....
It does tell us that the issue may be the same as this one...
Maybe something changed in a dependency when building the OctoPi image updated for 1.10.0 that is not compatible with a Pi Zero? I suspect existing installations will update fine.
What happens if you try and reinstall OctoPrint yourself?
Try installing 1.10.0 using this to rip all the dependencies out as well & reinstall them all.
I'm actually having what I believe is the exact same issue.
Just did a fresh install through the Pi Imager and having SSH'd in the OctoPrint dir is completely empty except for a README.txt, not even hidden files. As such nothing to do with the server itself exists.
Tried to install with manual disk image, no luck. Might have to install an outdated version...
Thanks to you too for trying to help me solve the problem!
I have been fideling with the board over SSH trying to install different versions of Octoprint as you suggested, and I have managed to - seemingly successfully - install versions 1.6.0 and 1.9.0, but installation of 1.10.0 keeps stalling while constructing a wheel for 'zeroconf':
Building wheels for collected packages: zeroconf
Building wheel for zeroconf (pyproject.toml) ... /
I still get the Illegal Instruction when requesting the system information though. In the process, I managed to request the system status, at get the following:
pi@octopi:~ $ sudo service octoprint restart
pi@octopi:~ $ service octoprint status
β octoprint.service - The snappy web interface for your 3D printer
Loaded: loaded (/etc/systemd/system/octoprint.service; enabled; vendor preset: enabled)
Active: failed (Result: signal) since Sun 2024-05-05 13:23:49 BST; 13s ago
Process: 1152 ExecStart=/home/pi/oprint/bin/octoprint serve --host=${HOST} --port=${PORT} (code=killed, >
Main PID: 1152 (code=killed, signal=ILL)
CPU: 1.711s
May 05 13:23:47 octopi systemd[1]: Started The snappy web interface for your 3D printer.
May 05 13:23:49 octopi systemd[1]: octoprint.service: Main process exited, code=killed, status=4/ILL
May 05 13:23:49 octopi systemd[1]: octoprint.service: Failed with result 'signal'.
May 05 13:23:49 octopi systemd[1]: octoprint.service: Consumed 1.711s CPU time.
The new OctoPrint 1.10.1 update, released today, should help to fix this issue. There is already a new image available through the RPi imager. If you're still struggling to get it running, please try this new image.
