Hello Team,
I have a problem on octoprint with my username or password.
I never change and it is "pi" and "raspberry" but today when I try to connect it doesn't work : incorrect username or password
Also I see the octopi on my home network and I also able to see my raspberry with advanced Ip scanner and obtain the IP adress
I have done the procedure to remount password directly with cmdline and then when I start the raspberry and enter loggin and password on the raspberry, it works but when I connect to my PC on octopi.local, I have the connection but the message "incorrect username and password" : I also check AZERTY and QWERTY keyboard but it is not the problem. I also have OCTOREMOTE on my mobile and it woks (but I can not see or change the loggin and password on it).
Could you help me to understand why it is impossible to connect from my PC
thanks
