Hello everybody,
i installed the "Thermal Runaway" from the "plugin repository"
and i can see it installed and activated in "plugin manager" but i can not see it in "plugins" list
I attach screenshot.
Thank you in advance for any input!
The plugin is failing to run as it is requiring Python 3, and you are using Python 2. However, I can't blame you for not knowing that it looks like it states Python 2 and 3 compatibility, despite Python 3-only syntax being added in.
You should upgrade to use Python 3:
But as pointed out, it doesn't look like you need the plugin.
Sorry im not familiar with codes and history My cr10max works fine.
I on purpose disengaged the power wires to the heated bed and left on the thermistor only to test for thermal runaway.
This thermal runaway comes from tiny-machines firmware for the cr10max. But i dont like it takes 6 minutes to kick in
This is why i was trying to install this plug in , so octoprin will cut mains to the printer with a "solid state relay" i made.
i dont like that my printers thermal runaway kicks in after 5 minuts minimum
ill try to study the forum how to upgrade to 1.7.0 because my updating tries fail and how to update to python 3 to instal this plug in and will let you know .
what a 5h evening journey
at last im now 1.7.0 with python 3 and can see "thermal runaway" plugin and tune it.
where r the good old days that all problems could be solved with a simple hammer .
