Hi guys,
I've set up OctoPrint via octopi image 0.18.0 on a RaspberryPi 4 8GB.
Printing works fine, but I have a 7" touchpanel attached to the pi, that I want to use to display the touchUI version of the OctoPrint interface.
I am not able do install chromium-browser to display the touchUI. When I hit sudo apt-get install chromium-browser I get the following errors:
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
chromium-browser:armhf : Depends: libcups2:armhf (>= 1.7.0) but it is not going to be installed
Depends: libgtk-3-0:armhf (>= 3.19.12) but it is not going to be installed
Depends: chromium-codecs-ffmpeg-extra:armhf (= 84.0.4147.105-rpt2) but it is not going to be installed or
chromium-codecs-ffmpeg:armhf (= 84.0.4147.105-rpt2) but it is not going to be installed
Depends: libraspberrypi0:armhf but it is not going to be installed
Recommends: chromium-browser-l10n:armhf but it is not installable
E: Unable to correct problems, you have held broken packages.
Linux octopi 5.4.72-v8+ #1356 SMP PREEMPT Thu Oct 22 13:58:52 BST 2020 aarch64, OctoPrint version : 1.4.2, OctoPi version: 0.18.0, Raspberry Pi 4 8GBHow do I solve this? The download page of the octopi image 0.18.0 says its highly experimental. I hope this is not a problem of octopi 0.18.0 image itself.
