When getting to this part, virtualenv venv, this is the error I get, yes, Python is installed.
'virtualenv' is not recognized as an internal or external command,
operable program or batch file.
pip --version = pip 20.2.1 from C:\Program Files\WindowsApps\PythonSoftwareFoundation.Python.3.8_3.8.1776.0_x64__qbz5n2kfra8p0\lib\site-packages\pip (python 3.8)
Started from scratch several times.
Complete Logs
octoprint.log
, serial.log
or output on terminal tab at a minimum, browser error console if UI issue ... no logs, no support! Not log excerpts, complete logs.)
