Intamsys Funmat HT
We have connected Octoprint to our Intamsys Funmat HT Enhanced Printer.
The Printer doess not do the right actions when starting a print, e.g. doesnt heat up, taking the right temperatur for the material. Does sombody have the right setup for this printer?
We use Octoprint 1.0.8.0 and the
It would be way more easy if you would not have deleted parts of the template that showed up when you started this thread.
So did you try in safe mode?
And logs are quite vital to make an assumption for what is going wrong.
IΒ΄m sorry - itΒ΄s my first time in this forum.
I now think, the main reason for octoprint running not smooth on the Intamsysprinter is, that settings like "preheat-time, nozzle temp, bed-temp, chamber-temp" are configurated in the printer. So the G-Code created with Intamsuite ist only a piece without information without preheat-time, nozzle temp, bed-temp, chamber-temp.
I'm afraid this printer is not that often in use by the forum members here.
The printer's company is quite restrictive with their information: For most everything they want to have my persona data.
For it seems to be a industrial machine, The firmware seems to be "optimized" for their needs and it may be difficult to attach the printer to OctoPrint.
If you can mange to share the logs (<- this is a link), we can see what could be possible to make it run.
octoprint.log (172.7 KB)
Hello!
I am also trying to use octoprint to work with a Intamsys Funmat HT Enhanced and it is not working right,
when i am able to work through octoprint the LCD touch stops working and octoprint does not detect all the tools, plus the z axis works upside down, also when you clic retract the printer actually extrude,
i attached the log files,
any help would be really help full, im trying to be able to print during the night,
Regards,
Alejandro castro
edit by mod: removed email so you don't get spammed :wink:
Hiho :slight_smile:
We also need the serial.log :slight_smile:
Please activate serial logging, connect to the printer, do some stuff (especially the stuff that doesn't work)
and upload the systeminfo bundle (click on the link for further instructions :slight_smile: )
The firmware appears to be a fork of Marlin and the slicer a fork of Ultimaker Cura and there appears to be a USB port so I'm guessing that OctoPrint can be configured to work.
Hello all. First off, sorry to bring back such an old thread.
@C_Telgen and/or @Alejandro_Castro : Did you guys ever succeed in setting up/using the Intamsys Funmat HT Enhanced with OctoPrint?
We have recently gotten one here at work and I have been tasked with setting it up - but am facing the same issues you all are describing. (The extruder wont extrude, the preheating functionality seems to be "in the printer" and all that)
So, did you manage it, and could you in that case assist in sharing your configuration/setup?
Thanks guys.
Hello @Hummpe !
Obviously not, else the thread would have a solution and would have been marked as Solved
Hi Ewald.
I was unable to control this settings via octoprint. I started to communicate with INTAMSYS also for other things but the supplier doesnt allow to configure anything in the 3D printer.
Hope you can find a way.
Thanks a lot for your reply.
I pass it on to @Hummpe .
