I'm trying to have the printer turned on automatically and switch off after a print. I've done some research and it states you need to have both PSU Control and the PSU Control - Tapo plugin. I have a TAPO smart plug connected to the printer which I can control manually using the app or by voice and create a schedules what not.
I've activated all plugins and input my credentials into the Tapo plugin in Octoprint, matching those in the Tapo app. Additionally, I've enabled the feature in the OctoPrint plugin in Cura for PSU control to automatically power up the printer when starting a print job. However, the printer doesn't turn on when I begin printing. I'm curious if this functionality is actually feasible, as I've heard the Tapo firmware update might disrupt the plugin's operation. If it's not possible, that's fine, but having this feature would be beneficial. As an alternative, I've installed PrintTime Genius, which accurately predicts the printing time, allowing me to schedule the printer to shut down 30 minutes post-printing. Ideally, having the printer automatically switch on and off would be great, but I understand that might not be achievable.
NO
Ok I've attached log which has been redacted.. Had my account details and IP's and passwords inside it other than that the information is correct. Also attached screenshots of the settings for the PSU controller and the Tapo would have just been my IP to the plug username and password which I've removed too.
Any information is greatly appreciated. Would be nice for this to work. So I take it the firmware isn't an issue no longer as I'm sure you guys would have mentioned it already ?
Yeah I've actually reserved it's IP address using it's MAC address therefore kind of making it static so the IP does not change. I can turn it off using voice by means of Alexa skill or I can use the app on android to turn on or off the plug.. so I think it's properly configured
no errors then, so maybe need to enable debug logging for the tapo plugin in OctoPrint's logging section. At least that way you can see if it's at least trying or not.
Actually it's not above listed with the other logs? Anyway this plugin isn't working. Where is this log please so we can see what's going on ? This is driving me round the bend
