Jerky printing after upgrading. Not sure if its Octoprint 1.6.0 or PSU 1.0.4
on request referencing:
Printing is jerky even when recalling a print which was done just prior to these two upgrades.
I have not tried running safe mode
System Info Bundle can be found in the link posted above.
PSU settings copied below (if there is a better way, other than select copy text, please let me know):
General
Show warning dialog when powering off via toggle button.
GPIO Device
/dev/gpiochip0
Pin numbers correspond to what is exposed by the GPIO device. Raspberry Pi Users: Use BCM numbering. See: https://pinout.xyz
Switching
Switching Method
GPIO
On/Off GPIO Pin
21
Invert
Enable switching with G-Code commands.
On G-Code Command
M80
Off G-Code Command
M81
Turn off when an unrecoverable firmware or communication error occurs.
Sensing
Sensing Method
GPIO
Sensing GPIO Pin
12
Float
Invert
Polling Interval
5
sec
Power On Options
Automatically turn PSU ON
Post On Delay
0
sec
Post On GCode Script
Connect when powered on.
Turn on prior to printing after API upload
Power Off Options
Automatically turn PSU OFF when idle
Idle Timeout
60
min
Ignore Commands
M105
Wait For Temperature
50
°C
Pre Off GCode Script
Disconnect on power off.
Here is the updated logs.
I have also included a short description of what I am doing with the GPIO below.:
BCM20 pin38 'Switching'
piconn<-- (input from PSU pluging)
# indicates PSU has been turned ON
# configured input set Pull Down to 0v while waiting GPIO.setup(20, GPIO.IN, pull_up_down=GPIO.PUD_DOWN)
# pin38 - to 1Kohm to pin40
#-->>>--(jumpered together)
BCM21 pin40
OctoPi_PSU--> (output to PSU plugin)
# OctoPi PSU-plugin switching is done on BCM21(5v sig) which is jumped to PiConn BCM20(pulldown)
# switching PSU (in this case we wait for it to go OFF for self shut down)
# configured in OctoPi_PSU plugin as BCM - 'GPIO 21'
BCM16 pin36 'Sensing'
piconn--> (output from piconn)
# confirms PSU is ON
# configured ouput set to LOW initially GPIO.setup(16, GPIO.OUT, initial=GPIO.LOW)
# pin36 to 1Kohm to pin32
#-->>--(jumpered together)
BCM12 pin32
OctoPi_PSU<-- (input from piconn)
# OctoPi PSU-plugin sense/bolt is done on BCM12(as FLOAT) which is jumped to PiConn BCM16(init LOW)
# Sensing of piconn state (turns on the electric bolt in OctoPi)
# configured in OctoPi_PSU plugin as BCM - 'GPIO 12'
2021-05-03 16:54:45,361 - octoprint.plugins.psucontrol - ERROR - Exception while setting up GPIO pin 12
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint_psucontrol/__init__.py", line 201, in configure_gpio
pin = periphery.CdevGPIO(path=self.config['GPIODevice'], line=self.config['senseGPIOPin'], direction='in', bias=bias)
File "/home/pi/oprint/lib/python3.7/site-packages/periphery/gpio.py", line 496, in __init__
self._open(path, line, direction, edge, bias, drive, inverted, label)
File "/home/pi/oprint/lib/python3.7/site-packages/periphery/gpio.py", line 547, in _open
self._reopen(direction, edge, bias, drive, inverted)
File "/home/pi/oprint/lib/python3.7/site-packages/periphery/gpio.py", line 553, in _reopen
raise GPIOError(None, "Line bias configuration not supported by kernel version {}.{}.".format(*KERNEL_VERSION))
periphery.gpio.GPIOError: [Errno None] Line bias configuration not supported by kernel version 5.4.
Huh I thought I had fixed that. You have two options:
A. Upgrade your kernel. Login via ssh and run sudo apt-get dist-upgrade. Be sure to make a backup first.
B. Install PSUControl-RPi.GPIO and configure PSUControl to use that.
I'd recommend trying A but nothing wrong with using B.
Wow! Thank you. I will try “C.” To get things tested out. Then proceed onward to upgrading the kernel and so forth. But first, thank you for your super quick assistance. I am currently trying to recover from a vaccine shot and will have more time at the end of this week (travel/work/essential nonsense!)
