Logitech C270 What is the problem?
Won't show up on OctoPrint. The light on the camera is on when I run mjpg streamer but the stream doesn't show up on the octo dashboard. After starting this post I tried to run the streamer again and it said that the http_output wasnt there, so I copied it back into the plugins folder(i had previously copied it out) and it still didn't work.
I installed and ran mjpg streamer.
sudo ./mjpg_streamer -i "./input_uvc.so -d /dev/video1 -r 1280x720 -f 30" -o "./output_http.so"
Logs (/var/log/webcamd.log, syslog, dmesg, ... no logs, no support) octoprint.log (162.7 KB)
I am using a Le Potato running Linux 22.04, octoprint version 0.2.3.
Camera Link : http://octoprint.local:8080/?action=stream
@Ewald_Ikemann Sorry about that, I just started playing around with Octoprint a few days ago so I forgot the terminology. I did mean the Octoprint GUI.
I changed the URLs back to what that post said (/webcam/?action=stream) and it still doesn't work.
And you are right, Version 1.8.7, Python 3.10.6 (I was looking in the wrong place)
I wanted to do a quick update because I still need help.
I did a complete redo, I switched to Armbian from Ubuntu and I got back to where Octoprint was running and accessible form the web page, but the camera still isn't working. I no longer have the error when I run mjpg-streamer.
