I'm trying to write a custom GCODE script and access the build volume height using context variables, yet I can't find full documentation on what is available for the print_profile context variable.
I see in https://docs.octoprint.org/en/master/features/gcode_scripts.html#context that the variable printer_profile is what I would use for the build volume, but I have yet to find any documentation of all the different parameters available. (Or is the proper term methods, what I mean are the terms after period(s) in the extended context variable name). For example in the documented default for the disable_hotends snipped I see printer_profile.extruder.count used, yet if I follow the link for printer_profile I don't see any documentation for the extruder attribute (method?).
Is there more complete documentation for, specifically, the printer_profile context variable that I haven't found yet?
Octoprint Version 1.4.2
OctoPi Version 0.17.0, running on Raspberry Pi 4 Model B Rev 1.1
