I have Ender 3 v2 and need faster printer which works with Octoprint (less than $700)?
WRITESearching youtube HERE
You can download this in OctoPrint's System Information dialog ... no bundle, no support! )
A difficult undertaking.
You may get a cheap and fast printer, but the quality is also cheap.
There are some far east products. They are low in price, a decent print quality and a bit faster than the the average. BUT: They often run an a very crippled Klipper system and there is almost no, at least no easy, way to connect it to OctoPrint.
The Sovol 8 could be a good fit. They just published everything as open source. Making it really close to the voron 2.4
You will have to do some updates but should be able to get it to work with Octoprint.
Afaik, the SV08 has no USB port. It can be a bit tricky to connect OctoPrint.
It also runs Klipper by default, so:
This information on pre installed Klipper on 3D-Printers
To access Klipper from OctoPrint, Klipper has to provide the /tmp/printer virttual USB port. The port name can be different. For this, OctoPrint must have access to this port. For this is a virtual and no physical USB port, OctoPrint must run on the same system as the Klipper installation. (Like classical OctoKlipper). The physical USB port of the printer is used by Klipper to communicate.
Over at the Klipper forum we made the experienc…
JCT5978
October 28, 2024, 10:32pm
5
The universal formula applies. Good, Fast, or Cheap. You get two. Good and fast, ain't going to be cheap. Good and cheap, ain't going to be fast. Fast and cheap, ain't going to be good.
Look for the Two Trees Sapphire Plus V3 - SP 5 V3.
