Low price fast printers that work with Octoprint?
I have Ender 3 v2 and need faster printer which works with Octoprint (less than $700)?
WRITESearching youtube HERE
A difficult undertaking.
You may get a cheap and fast printer, but the quality is also cheap.
There are some far east products. They are low in price, a decent print quality and a bit faster than the the average. BUT: They often run an a very crippled Klipper system and there is almost no, at least no easy, way to connect it to OctoPrint.
The Sovol 8 could be a good fit. They just published everything as open source. Making it really close to the voron 2.4
You will have to do some updates but should be able to get it to work with Octoprint.
Afaik, the SV08 has no USB port. It can be a bit tricky to connect OctoPrint.
It also runs Klipper by default, so:
The universal formula applies. Good, Fast, or Cheap. You get two. Good and fast, ain't going to be cheap. Good and cheap, ain't going to be fast. Fast and cheap, ain't going to be good.
Look for the Two Trees Sapphire Plus V3 - SP 5 V3.
I run 4x Sovol SV06's via OctoPrint without issue. Not super fast by modern standards, but I run them at around 100mm/s @2,000 - 5,000mm/s² using a 0.6mm nozzle using my custom Marlin fork:
