Lulzbot Taz 6 3D printer, at start of a print, machine homes X and Y then beeps until print canceled.
I've checked the usual suspects. The machine can home on all axis's without issue. I am observing a lot of disconnections in Octoprint and trying to determine if I have an issue within Octoprint or the Taz 6.
I am also noticing the same issue printing from the SD Card. And USB via Cura LE.
I don't suspect this is Octoprint but the serial log is showing some question mark characters which I can't decipher.
Made sure Octoprint is at the latest version.
Tested the Taz 6 can home XYZ, heat up nozzle and bed.
Did not try
Attached Serial and Octoprint log files
[octoprint-systeminfo-20240111005608.zip|attachment]
Windows 11 PC, Chrome Version 120.0.6099.216 (Official Build) (64-bit)
The issues with the connection you have is mostly a result of EMI.
This can be caused by high power devices near by and/or on the same power line.
Also a high quality USB cable is recommanded - and as short as possible.
