Mintemp Error-Heater ID 0
Poped out the SD card and it works all day. As long as I don't have the SD in when logging in it works. Corrupt SD?
Serial port list: ['/dev/ttyUSB0']
Connecting to: /dev/ttyUSB0
Connected to: Serial<id=0x6dd543d0, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Starting baud rate detection
Trying baudrate: 115200
Send: N0 M110 N0*125
Recv: start
Changing monitoring state from "Detecting baudrate" to "Operational"
Recv: echo: External Reset
Recv: Marlin
Recv: echo: Last Updated: 2015-12-01 12:00 | Author: (CR-10Slanguage)
Recv: Compiled: Dec 5 2017
Recv: echo: Free Memory: 1204 PlannerBufferBytes: 1232
Recv: echo:Hardcoded Default Settings Loaded
Recv: echo:Steps per unit:
Recv: echo: M92 X80.00 Y80.00 Z400.00 E93.00
Recv: echo:Maximum feedrates (mm/s):
Recv: echo: M203 X300.00 Y300.00 Z5.00 E25.00
Recv: echo:Maximum Acceleration (mm/s2):
Recv: echo: M201 X1000 Y1000 Z100 E5000
Recv: echo:Accelerations: P=printing, R=retract and T=travel
Recv: echo: M204 P500.00 R500.00 T1000.00
Recv: echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
Recv: echo: M205 S0.00 T0.00 B20000 X20.00 Z0.40 E5.00
Recv: echo:Home offset (mm):
Recv: echo: M206 X0.00 Y0.00 Z0.00
Recv: echo:Material heatup parameters:
Recv: echo: M145 M0 H185 B0 F0
Recv: echo: M145 M1 H240 B0 F0
Recv: echo:PID settings:
Recv: echo: M301 P22.20 I1.08 D114.00 C100.00 L20
Recv: echo:Filament settings: Disabled
Recv: echo: M200 D3.00
Recv: echo: M200 D0
Recv: echo:SD card ok
Recv: Init power off infomation.
Recv: size:
Recv: 591
Recv: init valid:
Recv: 0
Recv: 0
Recv: ok
Send: N1 M115*39
Recv: FIRMWARE_NAME:Marlin 1.1.0 From Archive SOURCE_CODE_URL:http:// ... PROTOCOL_VERSION:1.0 MACHINE_TYPE:www.cxsw3d.com EXTRUDER_COUNT:1 UUID:00000000-0000-0000-0000-000000000000
Recv: ok
Send: M21
Recv: ok
Send: M20
Recv: Begin file list
Recv: echo:Cannot open subdir
Recv: WIN7����
Recv: Error:MINTEMP triggered, system stopped! Heater_ID: 0
Changing monitoring state from "Operational" to "Error: MINTEMP triggered, system stopped! Heater_ID: 0"
Changing monitoring state from "Error: MINTEMP triggered, system stopped! Heater_ID: 0" to "Offline (Error: MINTEMP triggered, system stopped! Heater_ID: 0)"
