Missing .exe when installing on windows?
I followed the steps to install octoprint on Windows 11 though this link: Setting up OctoPrint on Windows
The server starts up when in the command prompt using "octoprint serve"
My issue resides with the next sections on creating a shortcut and startup service. The files in the folder consist of the following (below) while the documentation states looking for octoprint.exe.
activate
activate.bat
Activate.ps1
deactivate.bat
pip.exe
pip3.10.exe
pip3.exe
python.exe
pythonw.exe
I looked in the folder for the executable, but don't want to be clicking random things.
Not needed?
Safe mode not needed?
octoprint-systeminfo-20221013135505.zip (5.7 KB)
OctoPrint version:1.8.4
OctoPi version: N/A not on windows
Printer: N/A issue does not reside with printer and not connected yet
Firmware: N/A issue does not reside with printer firmware and not connected yet
Browser: Firefox V105.0.3
Operating system: Windows 11 Pro V21H2
Computer Specifications: Beelink SER4 AMD Ryzen 7 4700U 16GB RAM 500GB SSD
sounds like maybe you didn't activate the venv when installing octoprint and therefore it's found in your system python environment. If you open a command prompt and run c:\OctoPrint\venv\scripts\activate.bat and then run pip install octoprint do you then see the octoprint.exe in the correct location?
Another option is using my experimental windows installer.
doing .\activate.bat then pip install octoprint does not change anything in the directory.
Using your windows installer worked and added it as a startup service. Thank you!
New issue. Using localhost:5000 the local ip on port 5000 work on the device hosting the server, but the local ip does not load the site on any other device connected to the same network. Any ideas on that end?
Thanks for all your help!
Yeah, you have to use the computer's name or IP address on the network instead of localhost in that address. So something like http://192.168.0.100:5000/. You may have to modify window's firewall (or other security software) settings to allow the connection.
