MMU2S troubles, will not connect and print anymore
About a month ago I had a print going that messed up, blob on the print head and during removal, I broke the thermistor wire (it was heated an on to try and melt but I did not wait long enough.
I replaced the entire hot end assembly, re calibrated and got back in business, but my octoprint would not connect. SD card prints worked flawlessly.
Mind you I have a MK3s working flawlessly with the same setup with octoprint sitting next to the MMU2s/MK3s unit I can not connect.
Using a laptop and usb cable, I updated to the current firmware ... so USB port seems to work?
Formatted the micro sd card, downloaded latest octopi .17, inserted into the Pi and after a minute or 2 I was in octoprint setting up the profile.
EDIT: setup the profile using 5 extruders and shared nozzle as seen in another post
With the serial port and baud rate set, it would not connect, when i set it to auto it connected and said operational, when I went to send a print, it never asked for filament and after 30 seconds timed out.
one clip from the terminal:
Serial port list: ['/dev/ttyACM0']
Connecting to: /dev/ttyACM0
Connected to: Serial<id=0x6a5fa590, open=True>(port='/dev/ttyACM0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Starting baud rate detection...
Trying baudrate: 115200
Recv: start
Send: N0 M110 N0125
Changing monitoring state from "Detecting baudrate" to "Operational"
Send: N0 M110 N0
125
Recv: Command not found!
Send: N1 M115*39
logs removed because it has more than 2 links in it, will post in reply
About OctoPi
The ready-to-go Raspberry Pi image with OctoPrint
Version 0.17.0, running on Raspberry Pi 3 Model B Rev 1.2
OctoPrint
The snappy web interface for your 3D printer
Version 1.3.12
Really hope its something simple
i can't paste the logs because they have links (which to me are local file paths), if there is a way, please let me know and I will post
here is some
2019-11-30 18:00:21,560 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial port"
2019-11-30 18:00:21,577 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial port" to "Connecting"
2019-11-30 18:00:21,583 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2019-11-30 18:00:21,586 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2019-11-30 18:00:22,614 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2019-11-30 18:00:31,338 - octoprint.util.comm - INFO - Changing monitoring state from "Connecting" to "Offline"
2019-11-30 18:00:36,026 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial port"
2019-11-30 18:00:36,058 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial port" to "Opening serial port"
2019-11-30 18:00:36,065 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial port" to "Detecting baudrate"
2019-11-30 18:00:37,076 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2019-11-30 18:00:37,103 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting baudrate" to "Operational"
2019-11-30 18:00:37,114 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2019-11-30 18:00:46,876 - octoprint.printer.standard.job - INFO - Print job selected - origin: local, path: Terrain NED_-106.82_40.47_tile_1_1_0.2mm_PLA_MK3SMMU2S_2h45m.gcode, owner: pi, user: pi
2019-11-30 18:00:49,836 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Starting"
2019-11-30 18:00:49,852 - octoprint.printer.standard.job - INFO - Print job started - origin: local, path: Terrain NED_-106.82_40.47_tile_1_1_0.2mm_PLA_MK3SMMU2S_2h45m.gcode, owner: pi, user: pi
2019-11-30 18:01:07,136 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2019-11-30 18:01:22,226 - octoprint.server.util.flask - INFO - Passively logging in user pi from ::ffff:192.168.5.187
2019-11-30 18:01:27,238 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.5.187
2019-11-30 18:01:27,672 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.5.187
2019-11-30 18:01:27,767 - octoprint.server.util.flask - INFO - Passively logging in user pi from ::ffff:192.168.5.187
2019-11-30 18:01:30,026 - octoprint.server.util.sockjs - INFO - User pi logged in on the socket from client ::ffff:192.168.5.187
2019-11-30 18:01:37,167 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2019-11-30 18:02:07,197 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2019-11-30 18:02:37,227 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2019-11-30 18:03:07,257 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2019-11-30 18:03:37,287 - octoprint.util.comm - INFO - No response from printer after 6 consecutive communication timeouts, considering it dead.
2019-11-30 18:03:37,317 - octoprint.util.comm - INFO - Changing monitoring state from "Starting" to "Offline (Error: Too many consecutive timeouts, printer still
serial log
2019-11-30 17:50:19,913 - serial.log is currently not enabled, you can enable it via Settings > Serial Connection > Log communication to serial.log
2019-11-30 18:00:18,402 - Enabling serial logging
2019-11-30 18:00:21,544 - Connecting to: /dev/ttyACM0
2019-11-30 18:00:21,560 - Changing monitoring state from "Offline" to "Opening serial port"
2019-11-30 18:00:21,568 - Connected to: Serial<id=0x6c8efb30, open=True>(port='/dev/ttyACM0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2019-11-30 18:00:21,570 - Changing monitoring state from "Opening serial port" to "Connecting"
2019-11-30 18:00:21,584 - Send: N0 M110 N0*125
2019-11-30 18:00:21,587 - Send: N0 M110 N0*125
2019-11-30 18:00:22,604 - Recv: start
2019-11-30 18:00:22,615 - Send: N0 M110 N0*125
2019-11-30 18:00:31,332 - Connection closed, closing down monitor
2019-11-30 18:00:31,337 - Changing monitoring state from "Connecting" to "Offline"
2019-11-30 18:00:36,018 - Changing monitoring state from "Offline" to "Detecting serial port"
2019-11-30 18:00:36,052 - Serial port list: ['/dev/ttyACM0']
2019-11-30 18:00:36,053 - Connecting to: /dev/ttyACM0
2019-11-30 18:00:36,058 - Changing monitoring state from "Detecting serial port" to "Opening serial port"
2019-11-30 18:00:36,062 - Connected to: Serial<id=0x6c851570, open=True>(port='/dev/ttyACM0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2019-11-30 18:00:36,063 - Starting baud rate detection...
2019-11-30 18:00:36,065 - Changing monitoring state from "Opening serial port" to "Detecting baudrate"
2019-11-30 18:00:37,070 - Trying baudrate: 115200
2019-11-30 18:00:37,077 - Send: N0 M110 N0*125
2019-11-30 18:00:37,099 - Recv: start
2019-11-30 18:00:37,102 - Changing monitoring state from "Detecting baudrate" to "Operational"
2019-11-30 18:00:37,115 - Send: N0 M110 N0*125
2019-11-30 18:00:49,835 - Changing monitoring state from "Operational" to "Starting"
2019-11-30 18:01:07,138 - Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2019-11-30 18:01:07,147 - Send: N1 M115*39
2019-11-30 18:01:37,168 - Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2019-11-30 18:02:07,198 - Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2019-11-30 18:02:37,228 - Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2019-11-30 18:03:07,258 - Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2019-11-30 18:03:37,289 - No response from printer after 6 consecutive communication timeouts, considering it dead. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2019-11-30 18:03:37,316 - Changing monitoring state from "Starting" to "Offline (Error: Too many consecutive timeouts, printer still connected and alive?)"
2019-11-30 18:03:37,325 - Connection closed, closing down monitor
Did you set up your profile for multiple extruders?
yup, found that before I posted here but forgot to mention ... I've added up in the initial post
thanks for pointing that out.
-K
Do you have something else plugged to the USB ports of your Pi?
Can you operate the printer from the Laptop and Pronterface?
I do not, but found out it was RPI Port being set to the ON position that prevented it from working, I am resolved
