I try to connect my Printer, that workt after installing the " OctoPrint Malyan Connection Fix Plugin" but after a while the printer disconnect´s him self. While a print is runnig than the print stops (load on OctoPi) and i can´t connect it back. I need to restart the Printer.
The Pi ist Installed on Windows!!!
Install the " OctoPrint Malyan Connection Fix" Plugin
Switching the USB Cable
Cecked the USB Port on the Printer and the PI
Yes
Performing autodetection with 0 port/baudrate candidates:
Changing monitoring state from "Detecting serial connection" to "Error"
Performing autodetection with 7 port/baudrate candidates: /dev/ttyACM0@115200, /dev/ttyACM0@250000, /dev/ttyACM0@230400, /dev/ttyACM0@57600, /dev/ttyACM0@38400, /dev/ttyACM0@19200, /dev/ttyACM0@9600
Trying port /dev/ttyACM0, baudrate 115200
Connecting to: /dev/ttyACM0
Using Malyan/Monoprice Connection Fix Plugin to create serial connection
Handshake attempt #1 with timeout 2.0s
Connected to: Serial<id=0x6a5514f0, open=True>(port='/dev/ttyACM0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=2.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Send: N0 M110 N0125
Recv: ok N0 P15 B15
Changing monitoring state from "Detecting serial connection" to "Operational"
Send: N0 M110 N0125
Recv: ok N0 P15 B15
Send: N1 M11539
Unexpected error while reading serial port, please consult octoprint.log for details: SerialException: 'device reports readiness to read but returned no data (device disconnected or multiple access on port?)' @ comm.py:_readline:3997
Please see OctoPrint randomly loses connection to the printer with a "SerialException" - FAQ - OctoPrint Community Forum for possible reasons of this.
Changing monitoring state from "Operational" to "Offline after error"
Connected to: Serial<id=0x6fc8adf0, open=True>(port='/dev/ttyACM0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=2.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Send: N0 M110 N0125
Recv: ok N0 P15 B15
Send: N0 M110 N0125
Recv: ok N0 P15 B15
Send: N1 M11539
Recv: NAME. Malyan VER: 4.0 MODEL: M200 HW: HH02
Recv: CLK:EXT BUILD: Aug 10 2017 09:53:33
Recv: ok N1 P15 B15
Send: N2 M21*18
OctoPrint version 1.8.4, OctoPi version 0.18.0, PI is an 3B, printer Monoprice Select mini V2,browser Chrome,
Thanks for yor Help!!!
