Since the Update to 1.4.0 about 50% of the time when I start a print the normal start code executes to prime the nozzle. The printer then proceeds to move to the far rear corner and push through filament at an extreme rate until I reset the printer.
No changes made to printer firmware as was previously working fine and issue only occurs about 50% of the time. Currently reprinting the same G-code 10 times a day.
I have tried compiling the Gcode from Cura on 2 different computers and Simplify 3D. Issue occurs independant of the Gcode source and same GCode works sometimes and not others.
2020-05-01 17:02:12,486 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-05-01 17:02:22,604 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 2199}
2020-05-01 17:06:42,313 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.1.5
2020-05-01 17:14:26,264 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.1.14
2020-05-01 17:17:12,490 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-05-01 17:17:22,594 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 3099}
2020-05-01 17:19:53,511 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.5
2020-05-01 17:19:53,694 - octoprint.server.util.flask - INFO - Passively logging in user lyndon from ::ffff:192.168.1.5
2020-05-01 17:19:53,696 - octoprint.access.users - INFO - Logged in user: lyndon
2020-05-01 17:19:53,794 - octoprint.server.util.sockjs - INFO - User lyndon logged in on the socket from client ::ffff:192.168.1.5
2020-05-01 17:21:10,277 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.1.5
2020-05-01 17:23:40,780 - octoprint.util.comm - INFO - Finished in 3302.500 s.
2020-05-01 17:23:40,782 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Finishing"
2020-05-01 17:23:40,800 - octoprint.printer.standard.job - INFO - Print job done - origin: local, path: New_Mask_Strap_Plain_9mm_2.gcode, owner: lyndon
2020-05-01 17:23:40,858 - octoprint.util.comm - INFO - Changing monitoring state from "Finishing" to "Operational"
2020-05-01 17:23:41,318 - octoprint.plugins.tracking - INFO - Sent tracking event print_done, payload: {'origin': u'local', 'file': '605d4ad319e8e31b8734f073639378bfdf24b61b', u'elapsed': 3302}
2020-05-01 17:32:12,494 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-05-01 17:32:22,626 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 3999}
2020-05-01 17:47:12,497 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-05-01 17:47:22,645 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 4899}
2020-05-01 17:48:29,479 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.14
2020-05-01 17:48:29,631 - octoprint.server.util.flask - INFO - Passively logging in user lyndon from ::ffff:192.168.1.14
2020-05-01 17:48:29,632 - octoprint.access.users - INFO - Logged in user: lyndon
2020-05-01 17:48:29,736 - octoprint.server.util.sockjs - INFO - User lyndon logged in on the socket from client ::ffff:192.168.1.14
2020-05-01 17:48:47,733 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Starting"
2020-05-01 17:48:47,750 - octoprint.printer.standard.job - INFO - Print job started - origin: local, path: New_Mask_Strap_Plain_9mm_2.gcode, owner: lyndon, user: lyndon
2020-05-01 17:48:47,769 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-05-01 17:48:47,802 - octoprint.util.comm - INFO - Changing monitoring state from "Starting" to "Printing"
2020-05-01 17:48:48,118 - octoprint.plugins.tracking - INFO - Sent tracking event print_started, payload: {'origin': u'local', 'file': '605d4ad319e8e31b8734f073639378bfdf24b61b'}
2020-05-01 18:01:56,855 - octoprint.server.util.flask - INFO - Passively logging in user lyndon from ::ffff:192.168.1.5
2020-05-01 18:01:56,861 - octoprint.access.users - INFO - Logged in user: lyndon
2020-05-01 18:01:57,471 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.5
2020-05-01 18:01:57,591 - octoprint.server.util.flask - INFO - Passively logging in user lyndon from ::ffff:192.168.1.5
2020-05-01 18:01:57,593 - octoprint.access.users - INFO - Logged in user: lyndon
2020-05-01 18:01:59,456 - octoprint.server.util.sockjs - INFO - User lyndon logged in on the socket from client ::ffff:192.168.1.5
2020-05-01 18:02:10,330 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.1.5
2020-05-01 18:02:12,499 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-05-01 18:02:20,259 - octoprint.util.comm - WARNING - Printer sent 'start' while printing. External reset? Aborting job since printer lost state.
2020-05-01 18:02:20,273 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-05-01 18:02:20,286 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Cancelling"
2020-05-01 18:02:20,302 - octoprint.util.comm - INFO - Force-sending M108 to the printer
2020-05-01 18:02:20,327 - octoprint.printer.standard.job - INFO - Print job cancelled - origin: local, path: New_Mask_Strap_Plain_9mm_2.gcode, owner: lyndon, user: None
2020-05-01 18:02:20,764 - octoprint.plugins.tracking - INFO - Sent tracking event print_cancelled, payload: {'origin': u'local', 'file': '605d4ad319e8e31b8734f073639378bfdf24b61b', u'elapsed': 812}
2020-05-01 18:02:21,043 - octoprint.plugins.tracking - INFO - Sent tracking event print_failed, payload: {'origin': u'local', u'reason': u'cancelled', 'file': '605d4ad319e8e31b8734f073639378bfdf24b61b', u'elapsed': 812}
2020-05-01 18:02:23,372 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-05-01 18:02:23,474 - octoprint.util.comm - INFO - Changing monitoring state from "Cancelling" to "Operational"
2020-05-01 18:02:27,598 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 5799}
2020-05-01 18:02:38,833 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Starting"
2020-05-01 18:02:38,858 - octoprint.printer.standard.job - INFO - Print job started - origin: local, path: New_Mask_Strap_Plain_9mm_2.gcode, owner: lyndon, user: lyndon
2020-05-01 18:02:38,907 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-05-01 18:02:38,942 - octoprint.util.comm - INFO - Changing monitoring state from "Starting" to "Printing"
2020-05-01 18:02:39,254 - octoprint.plugins.tracking - INFO - Sent tracking event print_started, payload: {'origin': u'local', 'file': '605d4ad319e8e31b8734f073639378bfdf24b61b'}
Version 0.16.0, running on Raspberry Pi 3 Model B Rev 1.2
Octoprint Version 1.4.0
Any help apprceiated
