Raspberry pi
After upgrade to version of Octoprint 1.5.0 I made same print (same Gcode) and final timelapse in MP4 is 26,5 MB (previous file in MPEG2 has 16,3 MB)
I wrote about same problem here:
Is there some possibilities how to adjust settings of final MP4 file to reduce of size (bitrate etc.)?
I hope that main benefits of .mp4 files will be smaller size then .mpeg
Mediainfo of video files:
> General
> Complete name : C:\Users\sykoraj\Data\Plocha\Přílohy\2_20201201124826.mp4
> Format : MPEG-4
> Format profile : Base Media
> Codec ID : isom (isom/iso2/avc1/mp41)
> File size : 26.6 MiB
> Duration : 23 s 880 ms
> Overall bit rate : 9 329 kb/s
> Writing application : Lavf57.56.101
> Video
> Format : AVC
> Format/Info : Advanced Video Codec
> Format profile : High@L3.2
> Format settings, CABAC : Yes
> Format settings, ReFrames : 4 frames
> Codec ID : avc1
> Codec ID/Info : Advanced Video Coding
> Bit rate : 9 326 kb/s
> Nominal bit rate : 10 000 kb/s
> Width : 640 pixels
> Height : 480 pixels
> Display aspect ratio : 4:3
> Frame rate mode : Constant
> Frame rate : 25.000 FPS
> Color space : YUV
> Chroma subsampling : 4:2:0
> Bit depth : 8 bits
> Scan type : Progressive
> Bits/(Pixel*Frame) : 1.214
> Stream size : 26.5 MiB (100%)
> Writing library : x264 core 148 r2748 97eaef2
> Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=1 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=10000 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
> General
> Complete name : C:\Users\sykoraj\Data\Plocha\Přílohy\2_20201124102836.mpg
> Format : MPEG-PS
> File size : 16.4 MiB
> Duration : 23 s 440 ms
> Overall bit rate mode : Variable
> Overall bit rate : 5 867 kb/s
> Video
> Format : MPEG Video
> Format version : Version 2
> Format profile : Main@Main
> Format settings, BVOP : No
> Format settings, Matrix : Default
> Format settings, GOP : N=12
> Bit rate mode : Variable
> Bit rate : 5 750 kb/s
> Width : 640 pixels
> Height : 480 pixels
> Color space : YUV
> Bit depth : 8 bits
> Compression mode : Lossy
> Bits/(Pixel*Frame) : 0.749
> Time code of first frame : 00:00:00:00
> Time code source : Group of pictures header
> GOP, Open/Closed : Open
> GOP, Open/Closed of first frame : Closed
> Stream size : 16.1 MiB (98%)
browser.user_agent: Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.135 Safari/537.36
connectivity.connection_check: 8.8.8.8:53
connectivity.enabled: false
connectivity.online: true
env.hardware.cores: 4
env.hardware.freq: 1200
env.hardware.ram: 917016576
env.os.bits: 32
env.os.id: linux
env.os.platform: linux2
env.plugins.pi_support.model: Raspberry Pi 3 Model B Rev 1.2
env.plugins.pi_support.octopi_version: 0.15.1
env.python.pip: 19.2.3
env.python.version: 2.7.13
env.python.virtualenv: true
octoprint.safe_mode: false
octoprint.version: 1.5.0
printer.firmware: 3DFactories
Jan
