My octopi UI died (web UI not running) however octoeverywhere still runs and I'm able to print using that.
I can access PI using SSH but I'm a noob when it comes to linux.
Just did a reboot a few times
Yes
Well, the UI is dead, so no sysinfo bundle, and I cannot use octoeverywhere to fetch it since that redirect me 127.0.0.1 and even with the correct IP the http is dead anyway.
I have no clue how to create a system info from CLI and transfer the file to my PC.
It does show that something is running on port 5000, which would be OctoPrint. So OctoPrint is still running (and the fact you can get into it via OctoEverywhere supports this). Usually on OctoPi Haproxy runs on port 80 to proxy both OctoPrint and the webcam streaming to one place. So maybe that has died.
Maybe check sudo systemctl status haproxy.service to see if it is complaining of an error?
