My Octoprint Not Starts after update 1.10.0
I updated my octoprint installation via RC channel. Update went well but after restar
when I try to access it I receive this error page " The OctoPrint server is currently not running " with some instructions
I restarted system , tried to access GUI but not luck
I tried restarting Octoprint in Safe Mode via console no luck
I can not access to GUI hence could not produce SystemInfo Bundle
Here is the log file
octoprint.log (27.3 KB)
Hi there :tentacle:
It sounds like there was some kind of sd card corruption. This could indicate that the sd card is failing, so I would strongly advice you to backup OctoPrint and restore it on a fresh sd card.
Most of the time you're able to get OctoPrint back working (at least for some time) when you reinstall it
Of course you can continue using it if everything works fine afterwards, but there is a strong possibility that the card will fail completely soon.
