I can't connect to printer Ender 3 V3 SE with octoprint after install firmware to work with nebula pad
change serial port from AUTO to DEV/ttyUSB0
safe mode
Yes, same problem
no
OctoPrint 1.10.2 , * OctoPi* 1.0.0cam (build 2024.06.18.101629 , ender 3 v3 SE, firmware Jun 26, 2024 Ender3V3SE_firmware; Adaptive Ender-3 V3 SE
Hello @fernandoavf7 !
AFAIK, Creality put their mangled Klipper derivate on the printer.
There is no simple and no complex way to connect OctoPrint to that printer any more.
This information on pre installed Klipper on 3D-Printers
To access Klipper from OctoPrint, Klipper has to provide the /tmp/printer virttual USB port. The port name can be different. For this, OctoPrint must have access to this port. For this is a virtual and no physical USB port, OctoPrint must run on the same system as the Klipper installation. (Like classical OctoKlipper). The physical USB port of the printer is used by Klipper to communicate.
Over at the Klipper forum we made the experienc…
