2019-08-03 17:00:10,351 - Changing monitoring state from "Offline" to "Opening serial port"
2019-08-03 17:00:10,408 - Connected to: <octoprint_GPX.gpxprinter.GpxPrinter instance at 0x6be22580>, starting monitor
2019-08-03 17:00:10,409 - Changing monitoring state from "Opening serial port" to "Connecting"
2019-08-03 17:00:10,417 - Connection closed, closing down monitor
2019-08-03 17:00:10,418 - Closing down send loop
2019-08-03 17:00:15,067 - Changing monitoring state from "Offline" to "Opening serial port"
2019-08-03 17:00:15,083 - Connected to: <octoprint_GPX.gpxprinter.GpxPrinter instance at 0x6be7a800>, starting monitor
2019-08-03 17:00:15,090 - Starting baud rate detection...
2019-08-03 17:00:15,091 - Changing monitoring state from "Opening serial port" to "Detecting baudrate"
2019-08-03 17:00:16,108 - Trying baudrate: 115200
2019-08-03 17:00:16,153 - Recv: start
2019-08-03 17:00:16,158 - Send: N0 M110 N0*125
2019-08-03 17:00:16,197 - Changing monitoring state from "Detecting baudrate" to "Operational"
2019-08-03 17:00:16,220 - Recv: Makerbot v7.4
2019-08-03 17:00:16,222 - Send: N0 M110 N0*125
2019-08-03 17:00:16,263 - Recv: echo: gcode to x3g translation by GPX
2019-08-03 17:00:16,273 - Recv: SD init fail
2019-08-03 17:00:16,284 - Recv: T:25 /0 B:19 /0 T0:25 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:00:16,292 - Recv: T:25 /0 B:19 /0 T0:25 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:00:16,296 - Recv: T:25 /0 B:19 /0 T0:25 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:00:18,306 - Recv: ok
2019-08-03 17:00:18,308 - Send: M115
2019-08-03 17:00:18,313 - Recv: ok PROTOCOL_VERSION:0.1 FIRMWARE_NAME:Makerbot FIRMWARE_VERSION:7.4 FIRMWARE_URL:https://support.makerbot.com/learn/earlier-products/replicator-original/updating-firmware-for-the-makerbot-replicator-via-replicatorg_13302 MACHINE_TYPE:cr1d EXTRUDER_COUNT:2
2019-08-03 17:00:18,320 - Send: M21
2019-08-03 17:00:18,332 - Recv: ok
2019-08-03 17:00:18,334 - Send: M20
2019-08-03 17:00:18,334 - Recv: SD init fail
2019-08-03 17:00:18,343 - Recv: ok
2019-08-03 17:00:18,345 - Recv: Begin file list
2019-08-03 17:00:18,347 - Send: M876 P1
2019-08-03 17:00:18,349 - Recv: End file list
2019-08-03 17:00:18,355 - Recv: ok
2019-08-03 17:00:18,359 - Recv: // echo: (line 4) Syntax warning: unsupported mcode command 'M876'
2019-08-03 17:00:21,198 - Send: M105
2019-08-03 17:00:21,238 - Recv: ok T:25 /0 B:19 /0 T0:25 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:00:26,200 - Send: M105
2019-08-03 17:00:26,230 - Recv: ok T:25 /0 B:19 /0 T0:25 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:00:31,201 - Send: M105
2019-08-03 17:00:31,233 - Recv: ok T:25 /0 B:19 /0 T0:25 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:00:36,204 - Send: M105
2019-08-03 17:00:36,287 - Recv: ok T:25 /0 B:19 /0 T0:25 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:00:41,205 - Send: M105
2019-08-03 17:00:41,246 - Recv: ok T:25 /0 B:19 /0 T0:25 /0 T1:24 /0 @:0 B@:0
2019-08-03 17:00:46,244 - Send: M105
2019-08-03 17:00:46,287 - Recv: ok T:25 /0 B:19 /0 T0:25 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:00:51,247 - Send: M105
2019-08-03 17:00:51,279 - Recv: ok T:25 /0 B:19 /0 T0:25 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:00:56,248 - Send: M105
2019-08-03 17:00:56,283 - Recv: ok T:25 /0 B:19 /0 T0:25 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:01:01,250 - Send: M105
2019-08-03 17:01:01,291 - Recv: ok T:25 /0 B:19 /0 T0:25 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:01:06,252 - Send: M105
2019-08-03 17:01:06,290 - Recv: ok T:25 /0 B:19 /0 T0:25 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:01:11,254 - Send: M105
2019-08-03 17:01:11,289 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:01:16,256 - Send: M105
2019-08-03 17:01:16,291 - Recv: ok T:25 /0 B:19 /0 T0:25 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:01:21,258 - Send: M105
2019-08-03 17:01:21,292 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:01:26,260 - Send: M105
2019-08-03 17:01:26,298 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:01:31,261 - Send: M105
2019-08-03 17:01:31,294 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:01:36,300 - Send: M105
2019-08-03 17:01:36,382 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:01:41,303 - Send: M105
2019-08-03 17:01:41,342 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:01:46,305 - Send: M105
2019-08-03 17:01:46,346 - Recv: ok T:25 /0 B:19 /0 T0:25 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:01:51,306 - Send: M105
2019-08-03 17:01:51,341 - Recv: ok T:25 /0 B:19 /0 T0:25 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:01:56,308 - Send: M105
2019-08-03 17:01:56,347 - Recv: ok T:25 /0 B:19 /0 T0:25 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:02:01,315 - Send: M105
2019-08-03 17:02:01,349 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:02:06,317 - Send: M105
2019-08-03 17:02:06,354 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:02:11,356 - Send: M105
2019-08-03 17:02:11,397 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:02:16,393 - Send: M105
2019-08-03 17:02:16,433 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:02:21,394 - Send: M105
2019-08-03 17:02:21,435 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:02:26,396 - Send: M105
2019-08-03 17:02:26,434 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:02:31,398 - Send: M105
2019-08-03 17:02:31,430 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:02:36,399 - Send: M105
2019-08-03 17:02:36,438 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:02:41,401 - Send: M105
2019-08-03 17:02:41,436 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:02:46,403 - Send: M105
2019-08-03 17:02:46,440 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:02:51,404 - Send: M105
2019-08-03 17:02:51,446 - Recv: ok T:25 /0 B:19 /0 T0:25 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:02:56,406 - Send: M105
2019-08-03 17:02:56,440 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:03:01,442 - Send: M105
2019-08-03 17:03:01,482 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:03:06,444 - Send: M105
2019-08-03 17:03:06,480 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:03:11,445 - Send: M105
2019-08-03 17:03:11,527 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:03:16,447 - Send: M105
2019-08-03 17:03:16,481 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:03:21,448 - Send: M105
2019-08-03 17:03:21,481 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:03:26,450 - Send: M105
2019-08-03 17:03:26,491 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:03:31,452 - Send: M105
2019-08-03 17:03:31,490 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:03:36,454 - Send: M105
2019-08-03 17:03:36,484 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:03:41,456 - Send: M105
2019-08-03 17:03:41,491 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:03:46,492 - Send: M105
2019-08-03 17:03:46,530 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:03:51,494 - Send: M105
2019-08-03 17:03:51,575 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:03:56,496 - Send: M105
2019-08-03 17:03:56,530 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:04:01,497 - Send: M105
2019-08-03 17:04:01,538 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:04:06,498 - Send: M105
2019-08-03 17:04:06,533 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:04:11,534 - Send: M105
2019-08-03 17:04:11,572 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:04:16,567 - Send: M105
2019-08-03 17:04:16,599 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:04:21,611 - Send: M105
2019-08-03 17:04:21,650 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:04:26,612 - Send: M105
2019-08-03 17:04:26,652 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:04:31,614 - Send: M105
2019-08-03 17:04:31,647 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:04:36,616 - Send: M105
2019-08-03 17:04:36,655 - Recv: ok T:25 /0 B:19 /0 T0:25 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:04:41,619 - Send: M105
2019-08-03 17:04:41,653 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:04:46,621 - Send: M105
2019-08-03 17:04:46,658 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:04:51,624 - Send: M105
2019-08-03 17:04:51,659 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:04:56,624 - Send: M105
2019-08-03 17:04:56,663 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:05:01,662 - Send: M105
2019-08-03 17:05:01,702 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:05:06,705 - Send: M105
2019-08-03 17:05:06,796 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:05:11,742 - Send: M105
2019-08-03 17:05:11,779 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:05:16,782 - Send: M105
2019-08-03 17:05:16,815 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:05:21,783 - Send: M105
2019-08-03 17:05:21,824 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:05:26,818 - Send: M105
2019-08-03 17:05:26,855 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:05:31,820 - Send: M105
2019-08-03 17:05:31,858 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:05:36,821 - Send: M105
2019-08-03 17:05:36,906 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:05:41,823 - Send: M105
2019-08-03 17:05:41,861 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:05:46,824 - Send: M105
2019-08-03 17:05:46,859 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:05:51,827 - Send: M105
2019-08-03 17:05:51,858 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:05:56,827 - Send: M105
2019-08-03 17:05:56,867 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:06:01,834 - Send: M105
2019-08-03 17:06:01,871 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:06:06,870 - Send: M105
2019-08-03 17:06:06,904 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:06:11,872 - Send: M105
2019-08-03 17:06:11,954 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:06:16,874 - Send: M105
2019-08-03 17:06:16,913 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:06:21,875 - Send: M105
2019-08-03 17:06:21,913 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:06:26,877 - Send: M105
2019-08-03 17:06:26,909 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:06:31,878 - Send: M105
2019-08-03 17:06:31,967 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:06:36,880 - Send: M105
2019-08-03 17:06:36,918 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:06:41,883 - Send: M105
2019-08-03 17:06:41,921 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:06:46,918 - Send: M105
2019-08-03 17:06:46,955 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:06:51,920 - Send: M105
2019-08-03 17:06:51,952 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:06:56,921 - Send: M105
2019-08-03 17:06:56,961 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:07:01,923 - Send: M105
2019-08-03 17:07:01,956 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:07:06,925 - Send: M105
2019-08-03 17:07:06,961 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:07:11,963 - Send: M105
2019-08-03 17:07:12,000 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:07:16,998 - Send: M105
2019-08-03 17:07:17,039 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:07:21,999 - Send: M105
2019-08-03 17:07:22,031 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:07:27,001 - Send: M105
2019-08-03 17:07:27,032 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:07:32,004 - Send: M105
2019-08-03 17:07:32,043 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:07:37,004 - Send: M105
2019-08-03 17:07:37,036 - Recv: ok T:27 /0 B:19 /0 T0:27 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:07:42,008 - Send: M105
2019-08-03 17:07:42,051 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:07:47,010 - Send: M105
2019-08-03 17:07:47,049 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:07:52,044 - Send: M105
2019-08-03 17:07:52,082 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:07:57,045 - Send: M105
2019-08-03 17:07:57,086 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:08:02,087 - Send: M105
2019-08-03 17:08:02,132 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:08:07,134 - Send: M105
2019-08-03 17:08:07,166 - Recv: ok T:27 /0 B:19 /0 T0:27 /0 T1:25 /0 @:0 B@:0
2019-08-03 17:08:12,171 - Send: M105
2019-08-03 17:08:12,208 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:08:17,172 - Send: M105
2019-08-03 17:08:17,208 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:08:22,176 - Send: M105
2019-08-03 17:08:22,206 - Recv: ok T:27 /0 B:19 /0 T0:27 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:08:27,208 - Send: M105
2019-08-03 17:08:27,251 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:08:32,210 - Send: M105
2019-08-03 17:08:32,251 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:08:37,212 - Send: M105
2019-08-03 17:08:37,243 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:08:42,214 - Send: M105
2019-08-03 17:08:42,249 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:08:47,215 - Send: M105
2019-08-03 17:08:47,250 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:08:52,217 - Send: M105
2019-08-03 17:08:52,251 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:08:57,252 - Send: M105
2019-08-03 17:08:57,288 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:09:02,287 - Send: M105
2019-08-03 17:09:02,319 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:09:07,321 - Send: M105
2019-08-03 17:09:07,360 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:09:12,324 - Send: M105
2019-08-03 17:09:12,365 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:09:17,325 - Send: M105
2019-08-03 17:09:17,363 - Recv: ok T:27 /0 B:19 /0 T0:27 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:09:22,366 - Send: M105
2019-08-03 17:09:22,404 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:09:27,368 - Send: M105
2019-08-03 17:09:27,410 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:09:32,370 - Send: M105
2019-08-03 17:09:32,410 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:09:37,371 - Send: M105
2019-08-03 17:09:37,407 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:09:42,404 - Send: M105
2019-08-03 17:09:42,442 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:09:47,405 - Send: M105
2019-08-03 17:09:47,440 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:09:52,407 - Send: M105
2019-08-03 17:09:52,446 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:09:54,950 - Send: G91
2019-08-03 17:09:54,972 - Recv: ok
2019-08-03 17:09:54,978 - Send: G1 X10 F2500
2019-08-03 17:09:54,988 - Recv: ok
2019-08-03 17:09:55,010 - Send: G90
2019-08-03 17:09:55,010 - Recv: ok
2019-08-03 17:09:55,018 - Send: G91
2019-08-03 17:09:55,020 - Recv: ok
2019-08-03 17:09:55,024 - Send: G1 X-10 F2500
2019-08-03 17:09:55,033 - Recv: ok
2019-08-03 17:09:55,037 - Send: G90
2019-08-03 17:09:55,039 - Recv: ok
2019-08-03 17:09:55,041 - Send: G91
2019-08-03 17:09:55,043 - Recv: ok
2019-08-03 17:09:55,044 - Send: G1 X10 F2500
2019-08-03 17:09:55,053 - Recv: ok
2019-08-03 17:09:55,055 - Send: G90
2019-08-03 17:09:55,058 - Recv: ok
2019-08-03 17:09:55,114 - Send: G91
2019-08-03 17:09:55,128 - Recv: ok
2019-08-03 17:09:55,137 - Send: G1 Y-10 F2500
2019-08-03 17:09:55,158 - Recv: ok
2019-08-03 17:09:55,178 - Send: G90
2019-08-03 17:09:55,186 - Recv: ok
2019-08-03 17:09:55,188 - Send: G91
2019-08-03 17:09:55,189 - Recv: ok
2019-08-03 17:09:55,191 - Send: G1 Y-10 F2500
2019-08-03 17:09:55,201 - Recv: ok
2019-08-03 17:09:55,203 - Send: G90
2019-08-03 17:09:55,205 - Recv: ok
2019-08-03 17:09:55,207 - Send: G91
2019-08-03 17:09:55,210 - Recv: ok
2019-08-03 17:09:55,212 - Send: G1 Y-10 F2500
2019-08-03 17:09:55,222 - Recv: ok
2019-08-03 17:09:55,225 - Send: G90
2019-08-03 17:09:55,226 - Recv: ok
2019-08-03 17:09:55,227 - Send: G91
2019-08-03 17:09:55,230 - Recv: ok
2019-08-03 17:09:55,233 - Send: G1 Y10 F2500
2019-08-03 17:09:55,242 - Recv: ok
2019-08-03 17:09:55,244 - Send: G90
2019-08-03 17:09:55,246 - Recv: ok
2019-08-03 17:09:55,320 - Send: G91
2019-08-03 17:09:55,321 - Recv: ok
2019-08-03 17:09:55,345 - Send: G1 Y10 F2500
2019-08-03 17:09:55,356 - Recv: ok
2019-08-03 17:09:55,378 - Send: G90
2019-08-03 17:09:55,380 - Recv: ok
2019-08-03 17:09:55,404 - Send: G91
2019-08-03 17:09:55,407 - Recv: ok
2019-08-03 17:09:55,411 - Send: G1 Y10 F2500
2019-08-03 17:09:55,420 - Recv: ok
2019-08-03 17:09:55,422 - Send: G90
2019-08-03 17:09:55,425 - Recv: ok
2019-08-03 17:09:55,428 - Send: G91
2019-08-03 17:09:55,429 - Recv: ok
2019-08-03 17:09:55,431 - Send: G1 X-10 F2500
2019-08-03 17:09:55,439 - Recv: ok
2019-08-03 17:09:55,441 - Send: G90
2019-08-03 17:09:55,443 - Recv: ok
2019-08-03 17:09:55,445 - Send: G91
2019-08-03 17:09:55,445 - Recv: ok
2019-08-03 17:09:55,448 - Send: G1 X10 F2500
2019-08-03 17:09:55,454 - Recv: ok
2019-08-03 17:09:55,456 - Send: G90
2019-08-03 17:09:55,457 - Recv: ok
2019-08-03 17:09:55,459 - Send: G91
2019-08-03 17:09:55,462 - Recv: ok
2019-08-03 17:09:55,464 - Send: G1 X-10 F2500
2019-08-03 17:09:55,475 - Recv: ok
2019-08-03 17:09:55,477 - Send: G90
2019-08-03 17:09:55,478 - Recv: ok
2019-08-03 17:09:55,698 - Send: G91
2019-08-03 17:09:55,747 - Recv: ok
2019-08-03 17:09:55,749 - Send: G28 X0 Y0
2019-08-03 17:09:55,786 - Recv: T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:09:57,801 - Recv: ok
2019-08-03 17:09:57,813 - Send: G90
2019-08-03 17:09:57,816 - Recv: ok
2019-08-03 17:09:57,822 - Send: G91
2019-08-03 17:09:57,826 - Recv: ok
2019-08-03 17:09:57,831 - Send: G28 Z0
2019-08-03 17:09:57,866 - Recv: T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:09:59,883 - Recv: ok
2019-08-03 17:09:59,886 - Send: G90
2019-08-03 17:09:59,891 - Recv: ok
2019-08-03 17:09:59,894 - Send: G91
2019-08-03 17:09:59,897 - Recv: ok
2019-08-03 17:09:59,899 - Send: G1 Z10 F200
2019-08-03 17:09:59,911 - Recv: ok
2019-08-03 17:09:59,914 - Send: G90
2019-08-03 17:09:59,915 - Recv: ok
2019-08-03 17:09:59,918 - Send: G91
2019-08-03 17:09:59,919 - Recv: ok
2019-08-03 17:09:59,921 - Send: G1 Z10 F200
2019-08-03 17:09:59,929 - Recv: ok
2019-08-03 17:09:59,931 - Send: G90
2019-08-03 17:09:59,932 - Recv: ok
2019-08-03 17:09:59,935 - Send: G91
2019-08-03 17:09:59,936 - Recv: ok
2019-08-03 17:09:59,938 - Send: G1 Z10 F200
2019-08-03 17:09:59,945 - Recv: ok
2019-08-03 17:09:59,948 - Send: G90
2019-08-03 17:09:59,949 - Recv: ok
2019-08-03 17:09:59,951 - Send: G91
2019-08-03 17:09:59,953 - Recv: ok
2019-08-03 17:09:59,958 - Send: G1 Z-10 F200
2019-08-03 17:09:59,971 - Recv: ok
2019-08-03 17:09:59,978 - Send: G90
2019-08-03 17:09:59,980 - Recv: ok
2019-08-03 17:09:59,986 - Send: G91
2019-08-03 17:09:59,990 - Recv: ok
2019-08-03 17:09:59,995 - Send: G1 Z-10 F200
2019-08-03 17:10:00,004 - Recv: ok
2019-08-03 17:10:00,010 - Send: G90
2019-08-03 17:10:00,013 - Recv: ok
2019-08-03 17:10:00,017 - Send: G91
2019-08-03 17:10:00,019 - Recv: ok
2019-08-03 17:10:00,023 - Send: G1 Z-10 F200
2019-08-03 17:10:00,035 - Recv: ok
2019-08-03 17:10:00,039 - Send: G90
2019-08-03 17:10:00,042 - Recv: ok
2019-08-03 17:10:02,408 - Send: M105
2019-08-03 17:10:02,446 - Recv: ok T:27 /0 B:19 /0 T0:27 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:10:07,411 - Send: M105
2019-08-03 17:10:07,441 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
2019-08-03 17:10:12,412 - Send: M105
2019-08-03 17:10:12,448 - Recv: ok T:26 /0 B:19 /0 T0:26 /0 T1:26 /0 @:0 B@:0
