Need help with Serial Port Settings to connect
I can't get octoprint to connect with my printer and the dmesg output does not show the needed code in this help article - OctoPrint can't connect to my printer
I followed all steps in OctoPrint can't connect to my printer and it said to set up a Get Help ticket if it did not work.
Yes, that did not fix the issue
no
browser.user_agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/144.0.0.0 Safari/537.36
connectivity.enabled: True
connectivity.online: True
env.hardware.cores: 4
env.hardware.freq: 1000.0
env.hardware.ram: 379863040
env.os.bits: 32
env.os.id: linux
env.os.platform: Linux-6.6.51+rpt-rpi-v7-armv7l-with-glibc2.36
env.plugins.pi_support.model: Raspberry Pi Zero 2 W Rev 1.0
env.plugins.pi_support.octopi_camera_stack: webcamd
env.plugins.pi_support.octopi_version: 1.1.0
env.plugins.pi_support.octopiuptodate_build: 1.1.0-1.11.6-20260127133909
env.plugins.pi_support.octopiuptodate_build_short: 2026.01.27.133909
env.python.pip: 25.0.1
env.python.version: 3.11.2
env.python.virtualenv: True
octoprint.last_safe_mode.date: 2026-01-30T18:07:57Z
octoprint.last_safe_mode.reason: settings
octoprint.safe_mode: True
octoprint.version: 1.11.6
systeminfo.generated: 2026-01-30T18:13:16Z
systeminfo.generator: zipapi
My printer is a Prusa i3 MK3S and I am using a Raspberry Pi Zero 2
Hello @Brian_Luley !
Please attach the requested systeminfo bundle to your next post.
Usually for that printer you set:
grafik
Also: Have you checkt the USB cable for proper data connection?
I dont see any serial port option but 'AUTO' unfortunately and they isnt selectable.
Here is the systeminfo though -
octoprint-systeminfo-20260202151825.zip (12.3 KB)
Hi @Ewald_Ikemann , thank you for the help. I included the systeminfo file below. Does that help?
How do I check if the USB cable is working? I have already completed an update with it.
Ultimately, I am trying to connect my printer to the comp wirelessly through the Raspberry Pi I have installed with OctoPrint
