Network error while checking for updates
#1
Software update gives this error on every item
Manual update, pip re install, reflash of SD, change of DNS
Octpi 0.14
Updated to dev -OctoPrint: 1.4.0.dev806+g03d421c trying to solve issue with no help
Pi 3
Network cable plugged directly into main router
All functions work perfectly including accessing Octoprint from outside the network. Installing plugins works perfectly.
#2
What error? Also please share your logs, both the application log and the software update log. See
https://discourse.octoprint.org/t/where-can-i-find-octoprints-log-files/299?u=foosel
#3
The error is - Network error while checking for updates, thats exactly what it says on every item. But when you hit check for updates the box pops up and says up to date but they are not.
#4
There's no way to help you unless you share your logs.
#5
I am trying to upload the log but it wont let me I am looking for a alternative upload service
#6
https://drive.google.com/file/d/1YxihGkIl6jSGAziPHVLoA1-KTHQ9QFkU/view?usp=sharing
#7
the only log i see for software update is blank when you open it, is there any other log you would want other then the main one?
#8
Looks like it isn't even trying to start the software update because it's already falling on its face while looking for updates.
Since it requires an SSL connection to the Github servers to work for that, I suggest to check item 1 and 3 here:
https://discourse.octoprint.org/t/i-cant-install-any-plugins-from-the-repository-it-is-unreachable/178
but instead of testing if you can reach plugins.octoprint.org to test if you can reach api.github.com. Also check and provide what output a
~/oprint/bin/python -c "import requests; r=requests.get('https://api.github.com'); print(repr(r))"
produces.
#9
Set time to UTC and verified time
Pinging all three locations come out good
pi@octopi:~ $ pi@octopi:~ $ ~/oprint/bin/python -c "import requests; r=requests.get('https://api.github.com'); print(repr(r))"
-bash: pi@octopi:~: command not found
pi@octopi:~ $ Traceback (most recent call last):
-bash: syntax error near unexpected token `most'
pi@octopi:~ $   File "<string>", line 1, in <module>
-bash: syntax error near unexpected token `newline'
pi@octopi:~ $   File "/home/pi/oprint/local/lib/python2.7/site-packages/requests-2.18.4-py2.7.egg/requests/api.py", line 72, in get
-bash: File: command not found
pi@octopi:~ $     return request('get', url, params=params, **kwargs)
-bash: syntax error near unexpected token `('
pi@octopi:~ $   File "/home/pi/oprint/local/lib/python2.7/site-packages/requests-2.18.4-py2.7.egg/requests/api.py", line 58, in request
pi@octopi:~ $     return session.request(method=method, url=url, **kwargs)
pi@octopi:~ $   File "/home/pi/oprint/local/lib/python2.7/site-packages/requests-2.18.4-py2.7.egg/requests/sessions.py", line 508, in request
pi@octopi:~ $     resp = self.send(prep, **send_kwargs)
pi@octopi:~ $   File "/home/pi/oprint/local/lib/python2.7/site-packages/requests-2.18.4-py2.7.egg/requests/sessions.py", line 618, in send
pi@octopi:~ $     r = adapter.send(request, **kwargs)
pi@octopi:~ $   File "/home/pi/oprint/local/lib/python2.7/site-packages/requests-2.18.4-py2.7.egg/requests/adapters.py", line 506, in send
pi@octopi:~ $     raise SSLError(e, request=request)
pi@octopi:~ $ requests.exceptions.SSLError: HTTPSConnectionPool(host='api.github.com', port=443): Max retries exceeded with url: / (Caused by SSLError(SSLError(1, u'[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:581)'),))
#10
You are definitely getting an SSL certificate validation error though, just as I feared. If the date and time are indeed correct then I'm unsure right now how best to narrow the cause of this down further. Maybe someone else has an idea.
#11
Yha i just read that at the bottom, at least i am closer to the issue
#12
Got it - It was a DNS error on the Pi, I ran int the same issue on a Pi running Pi-Star on a friend of mines network. Even tho Octoprint's connectivity setting is checking 8.8.8.8 it was using 192.168.1.1 and falling flat on it's face.
I did the following to it
I edited
/etc/network/interfaces
to add
dns-nameservers 8.8.4.4 208.67.222.222
And software update is working now
running your command above now equals
<Response [200]>
I think it is a Netgear router issue with Raspberry Pi's since his issue started when he changed to one and I am running the same model since last year.
#13
Perfect! Don't forget to mark your answer as the solution so others facing the same issue might find it easily.
#14
For anyone stumbling upon this thread, I had a similar problem and it was due to a PiHole on my network that was blocking requests to https://codeload.github.com/, as it's commonly used to host malicious software.
Adding that to the whitelist resolved the issue!
OctoPrint 1.3.11 Update Fails to Install
