I read this Camera-streamer configuration on the new camera stack for OctoPi
I have the new camera stack working well with my Logitech C920 using the default USB camera config file. I would like to customize some settings, but I can't find the syntax for the options I want to change. I have found many in this post, but not all. I tried $ camera-streamer --help and got the same thing published here. When I tried $ camera-streamer --camera-list_options, I expected to see a list of the camera's options, but I got this instead:
camera-streamer Version: v0.2.5 (41d8dfd)
device/v4l2/device.c: CAMERA: Device path=/dev/video0 fd=3 opened
device/v4l2/device_options.c: CAMERA: The 'horizontal_flip=0' was failed to find.
device/v4l2/device_options.c: CAMERA: The 'vertical_flip=0' was failed to find.
device/camera/camera_input.c: CAMERA: Disabling DMA since device uses USB (which is likely not working properly).
device/v4l2/buffer_list.c: CAMERA:capture: ioctl(ret=-1, errno=16): Can't set format
Ayufan posted "All available configs can be found here: libcamera/control_ids.yaml ..." but that yaml file talks about controls and return codes; I don't understand how to use that document when setting camera options.
I am looking specifically for the options to turn off autofocus and set manual focus to a specific value, turn off autoexposure and set exposure to a specific value, same with setting manual white balance. I can do those things from the control app at octopi.local/webcam/control, but I want to make the settings persistent.
Is there a list somewhere of all the available options?
