Once my RPi4 boots up, I can connect to it through octopi.local, but when I click on "Connect" I get errors. Some suggesting I choose the Serial Port manually. When I go to the drop down for Serial Port, I only have AUTO available. I can't find or connect to my printer. Trying to connect RPi4b 4G to an Ender 3 v2.
tried using 64 gb card, and 32 gb card.
Formatted multiple times. FAT32 format. Downloaded img file from octoprint. installed via Belena Etcher.
Tried 4 different usb-a to micro usb cable.
Put tape over the power pin of the USB-A side of the cable.
Powered off and on my printer while connected. Refreshed browser after connection.
Firmware update for my printer.
Everything I do results in the same outcome.
Performing autodetection with 0 port/baudrate candidates:
Changing monitoring state from "Detecting serial connection" to "Error: No more candidates to test, and no working port/baudrate combination detected."
I did get one error one time mentioning it could not connect so Serial port automatically, and had to be done manually. But there was nothing in the drop down for Serial Ports.
Complete Logs
Its this same lines over and over (each time I hit connect):
Using MacBook Pro to flash microSD card.
64gb or 32 gb card.
Raspberry Pi 4b 4gb
Ender 3 v2
TiA!
