After sudo apt upgrade I cant connect to the webinterface of octoprint. SSH connection still works.
ps -ef | grep -i octoprint | grep -i python: no output
sudo service octoprint restart: does nothing. Service doesnt start
I have had an error because of /etc/ld.so.preload there I commented out ������������������������������������������������������
yes
no
I am unable to create a systeminfo bundle because I cannot access the UI. From the command line when I try octoprint systeminfo . I get a command not found.
Raspberry Pi Zero 2WH, 32GB Sandisk Ultra, OctoPrint version : 1.11.5
OctoPi version : 1.1.0
~/.octoprint/logs/octoprint.log:
2026-01-15 05:16:13,786 - octoprint.startup - INFO - ******************************************************************************
2026-01-15 05:16:13,790 - octoprint.startup - INFO - Starting OctoPrint 1.11.5
2026-01-15 05:16:13,792 - octoprint.startup - INFO - Starting in SAFE MODE. Third party plugins will be disabled!
2026-01-15 05:16:13,792 - octoprint.startup - INFO - Reason for safe mode: setting in config.yaml
2026-01-15 05:16:13,793 - octoprint.startup - INFO - ******************************************************************************
2026-01-15 05:16:15,283 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity changed from offline to online
2026-01-15 05:16:15,299 - octoprint.util.connectivity.connectivity_checker - INFO - Connectivity state is currently: online
2026-01-15 05:16:15,299 - octoprint.util.connectivity.connectivity_checker - INFO - Connecting to 1.1.1.1:53 is working
2026-01-15 05:16:15,299 - octoprint.util.connectivity.connectivity_checker - INFO - Resolving octoprint.org is working
2026-01-15 05:16:15,820 - octoprint.startup - INFO - Blacklist processing done, adding 4 blacklisted plugin versions: roomtemp (any), GcodeEditor (>=0.1.1,<=0.2.8), gcodeleveling (>=0.1.0,<=0.1.1), PrintTimeGe>
2026-01-15 05:16:15,829 - octoprint.plugin.core - INFO - Loading plugins from /opt/octopi/oprint/lib/python3.11/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2026-01-15 05:16:17,851 - octoprint.plugin.core - ERROR - Error loading plugin softwareupdate
File "/opt/octopi/oprint/lib/python3.11/site-packages/octoprint/plugin/core.py", line 1339, in _import_plugin
module = _load_module(spec)
File "/opt/octopi/oprint/lib/python3.11/site-packages/octoprint/plugin/core.py", line 74, in _load_module
spec.loader.exec_module(sys.modules[spec.name])
File "", line 940, in exec_module
File "", line 241, in _call_with_frames_removed
File "/opt/octopi/oprint/lib/python3.11/site-packages/octoprint/plugins/softwareupdate/init.py", line 25, in
from octoprint.server import BRANCH, NO_CONTENT, REVISION, VERSION
File "/opt/octopi/oprint/lib/python3.11/site-packages/octoprint/server/init.py", line 50, in
from octoprint.server import util
File "/opt/octopi/oprint/lib/python3.11/site-packages/octoprint/server/util/init.py", line 22, in
from . import flask, sockjs, tornado, watchdog # noqa: F401
ValueError: source code string cannot contain null bytes
2026-01-15 05:16:18,614 - octoprint.plugin.core - ERROR - Error loading plugin appkeys
File "/opt/octopi/oprint/lib/python3.11/site-packages/octoprint/plugins/appkeys/init.py", line 12, in
from octoprint.server import NO_CONTENT, current_user
2026-01-15 05:16:18,728 - octoprint.plugin.core - ERROR - Error loading plugin gcodeviewer
File "/opt/octopi/oprint/lib/python3.11/site-packages/octoprint/plugins/gcodeviewer/init.py", line 11, in
from octoprint.server.util.flask import no_firstrun_access
2026-01-15 05:16:18,982 - octoprint.plugin.core - ERROR - Error loading plugin announcements
File "/opt/octopi/oprint/lib/python3.11/site-packages/octoprint/plugins/announcements/init.py", line 22, in
from octoprint.server.util.flask import (
2026-01-15 05:16:19,207 - octoprint.plugin.core - ERROR - Error loading plugin backup
File "/opt/octopi/oprint/lib/python3.11/site-packages/octoprint/plugins/backup/init.py", line 8, in
2026-01-15 05:16:19,844 - octoprint.plugin.core - ERROR - Error loading plugin logging
File "/opt/octopi/oprint/lib/python3.11/site-packages/octoprint/plugins/logging/init.py", line 14, in
2026-01-15 05:16:20,131 - octoprint.plugin.core - ERROR - Error loading plugin pluginmanager
File "/opt/octopi/oprint/lib/python3.11/site-packages/octoprint/plugins/pluginmanager/init.py", line 28, in
from octoprint.server import safe_mode
2026-01-15 05:16:20,660 - octoprint.plugin.core - INFO - Found 23 plugin(s) providing 16 mixin implementations, 28 hook handlers
2026-01-15 05:16:20,895 - octoprint.cli.server - ERROR - Uncaught exception
File "/opt/octopi/oprint/bin/octoprint", line 8, in
sys.exit(main())
File "/opt/octopi/oprint/lib/python3.11/site-packages/octoprint/init.py", line 1030, in main
octo(args=args, prog_name="octoprint", auto_envvar_prefix="OCTOPRINT")
File "/opt/octopi/oprint/lib/python3.11/site-packages/click/core.py", line 1161, in call
return self.main(*args, **kwargs)
File "/opt/octopi/oprint/lib/python3.11/site-packages/click/core.py", line 1082, in main
rv = self.invoke(ctx)
File "/opt/octopi/oprint/lib/python3.11/site-packages/click/core.py", line 1697, in invoke
return _process_result(sub_ctx.command.invoke(sub_ctx))
File "/opt/octopi/oprint/lib/python3.11/site-packages/click/core.py", line 1443, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "/opt/octopi/oprint/lib/python3.11/site-packages/click/core.py", line 788, in invoke
return __callback(*args, **kwargs)
File "/opt/octopi/oprint/lib/python3.11/site-packages/click/decorators.py", line 33, in new_func
return f(get_current_context(), *args, **kwargs)
File "/opt/octopi/oprint/lib/python3.11/site-packages/octoprint/cli/server.py", line 326, in serve_command
run_server(
File "/opt/octopi/oprint/lib/python3.11/site-packages/octoprint/cli/server.py", line 149, in run_server
from octoprint.server import CannotStartServerException, Server
