Camera modelPi Camera Rev 1.3
What is the problem? Cannot get the Camera or WebCam to work with or without OctoPi.
Tried two different cameras
Tried three different Raspberry Pi's (two Pi 3b, one Pi 4)
Recreated 4 separate SDMicro cards using Raspi Pi Imager v1.7.1
Tried with Four different cables
The results are the same, no webcam via OctoPi or elsewhere.
I can run raspistill -o test.jpg. The LED on the camera lights.
After about 15 seconds, I get an error that says No data received from the sensor.
I Control-C to exit and look for the JPG, it's there, zero bytes.
What am I missing????
Sorry for the lengthy log data.....
Starting up webcamDaemon...
cfg_file: /boot/octopi.txt
camera: auto
usb options: -r 640x480 -f 10
raspi options: -fps 10
Explicitly USB device:
Found video devices:
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
raspi
config file='/boot/octopi.txt':USB device was not set in options, start MJPG-streamer with the first found video device: /dev/video0
<13>Dec 2 12:56:14 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 640x480 -f 10 -d /dev/video0
Goodbye...
i: Frames Per Second.: 10
i: Format............: JPEG
o: HTTP Listen Address..: 127.0.0.1
i: select() timeout
i: cleaning up resources allocated by input thread
camera: auto
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
raspi
<13>Feb 25 19:06:02 root: Starting USB webcam
Goodbye...
i: select() timeout
camera: auto
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
raspi
<13>Feb 25 19:19:41 root: Starting USB webcam
Goodbye...
i: select() timeout
camera: auto
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
raspi
<13>Feb 25 19:26:03 root: Starting USB webcam
Goodbye...
i: select() timeout
camera: auto
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
raspi
<13>Feb 25 19:30:11 root: Starting USB webcam
Serial.log: 2022-02-25 19:44:14,689 - Enabling serial logging
SystemInfo: browser.user_agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/98.0.4758.102 Safari/537.36
connectivity.enabled: True
connectivity.online: True
env.hardware.cores: 4
env.hardware.freq: 1200.0
env.hardware.ram: 914010112
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.model: Raspberry Pi 3 Model B Rev 1.2
env.python.pip: 20.3.3
env.python.version: 3.7.3
env.python.virtualenv: True
octoprint.safe_mode: False
octoprint.version: 1.7.3
systeminfo.generator: zipapi
OctoPrint.log:
2022-02-25 19:30:25,635 - octoprint.environment - INFO - Detected environment is Python 3.7.3 under Linux (linux). Details:
| hardware:
| cores: 4
| freq: 1200.0
| ram: 914010112
| os:
| bits: 32
| platform: linux
| plugins:
| pi_support:
| throttle_state: '0x0'
| python:
| pip: 20.3.3
| version: 3.7.3
| virtualenv: /home/pi/oprint
2022-02-25 19:30:25,648 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2022-02-25 19:30:25,669 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2022-02-25 19:30:26,630 - octoprint.server - INFO - Shutting down intermediary server...
2022-02-25 19:30:27,119 - octoprint.server - INFO - Intermediary server shut down
2022-02-25 19:30:27,121 - octoprint.events - INFO - Processing startup event, this is our first event
2022-02-25 19:30:27,122 - octoprint.events - INFO - Adding 2 events to queue that were held back before startup event
2022-02-25 19:30:27,132 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2022-02-25 19:30:27,152 - octoprint.plugins.softwareupdate - INFO - Fetching check overlays from https://plugins.octoprint.org/update_check_overlay.json
2022-02-25 19:30:27,183 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2022-02-25 19:30:27,184 - octoprint.server.util.watchdog - INFO - Running initial scan on watched folder...
2022-02-25 19:30:27,217 - octoprint.server.util.watchdog - INFO - ... initial scan done.
2022-02-25 19:30:27,218 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2022-02-25 19:30:28,337 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi._http._tcp.local.' for _http._tcp.local.
2022-02-25 19:30:29,162 - octoprint.plugins.tracking - INFO - Sent tracking event system_unthrottled, payload: {'throttled_now': False, 'throttled_past': False, 'throttled_mask': 0, 'throttled_voltage_now': False, 'throttled_voltage_past': False, 'throttled_overheat_now': False, 'throttled_overheat_past': False}
2022-02-25 19:30:29,245 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi._octoprint._tcp.local.' for _octoprint._tcp.local.
2022-02-25 19:30:29,264 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for SSDP
2022-02-25 19:30:29,357 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2022-02-25 19:30:29,577 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2022-02-25 19:30:29,986 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2022-02-25 19:30:30,631 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python3 -m pip" as command to invoke pip
2022-02-25 19:30:30,638 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python3.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2022-02-25 19:30:30,639 - octoprint.util.pip - INFO - ==> pip ok -> yes
2022-02-25 19:30:30,658 - octoprint.plugins.softwareupdate - INFO - Minimum free storage across all update relevant locations is 26.1GB. That is considered sufficient for updating.
2022-02-25 19:30:31,994 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'base_url': 'http://192.168.55.250/', 'path': '/', 'query_string': 'l10n=en'}
2022-02-25 19:30:32,073 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2022-02-25 19:30:33,492 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 8, 'printer_state': 'OFFLINE'}
2022-02-25 19:30:35,155 - octoprint.plugins.tracking - INFO - Sent tracking event pong, payload: {'version': '1.7.3', 'os': 'linux', 'bits': 32, 'python': '3.7.3', 'pip': '20.3.3', 'cores': 4, 'freq': 1200.0, 'ram': 914010112, 'pi_model': 'Raspberry Pi 3 Model B Rev 1.2', 'octopi_version': '0.18.0', 'plugins': ''}
2022-02-25 19:30:36,912 - octoprint.plugins.tracking - INFO - Sent tracking event startup, payload: {'version': '1.7.3', 'os': 'linux', 'bits': 32, 'python': '3.7.3', 'pip': '20.3.3', 'cores': 4, 'freq': 1200.0, 'ram': 914010112, 'pi_model': 'Raspberry Pi 3 Model B Rev 1.2', 'octopi_version': '0.18.0'}
2022-02-25 19:34:21,462 - octoprint.server.preemptive_cache - INFO - ... done in 11.76s
2022-02-25 19:42:39,139 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.55.102
2022-02-25 19:42:48,492 - octoprint.access.users - INFO - Logged in user: jjlocke
2022-02-25 19:42:48,496 - octoprint.server.api - INFO - Actively logging in user jjlocke from ::ffff:192.168.55.102
2022-02-25 19:42:48,596 - octoprint.server.util.flask - INFO - Passively logging in user jjlocke from ::ffff:192.168.55.102
2022-02-25 19:42:48,596 - octoprint.access.users - INFO - Logged in user: jjlocke
2022-02-25 19:42:48,637 - octoprint.server.util.flask.PreemptiveCache - INFO - Adding entry for / and {'path': '/', 'base_url': 'http://octopi/', 'query_string': 'l10n=en', '_timestamp': 1645818168.6378338, '_count': 1}
2022-02-25 19:42:48,992 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.55.102
2022-02-25 19:42:49,583 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.55.102
2022-02-25 19:42:49,610 - octoprint.server.util.flask - INFO - Passively logging in user jjlocke from ::ffff:192.168.55.102
2022-02-25 19:42:49,611 - octoprint.access.users - INFO - Logged in user: jjlocke
2022-02-25 19:42:50,679 - octoprint.server.util.sockjs - INFO - User jjlocke logged in on the socket from client ::ffff:192.168.55.102
2022-02-25 19:42:55,479 - octoprint.plugins.tracking - INFO - Sent tracking event webui_load, payload: {'browser_name': 'Chrome', 'browser_version': '98.0.4758.102', 'os_name': 'Windows', 'os_version': '10'}
2022-02-25 19:43:39,782 - octoprint.plugins.logging - INFO - Setting logger octoprint level to 10
2022-02-25 19:44:15,196 - octoprint.events.fire - DEBUG - Firing event: SettingsUpdated (Payload: {'config_hash': '28d05ad5d7608792dab2aacbe7090509', 'effective_hash': 'e24e448f495ab4f8e2c375c9f6e1c76c'})
2022-02-25 19:44:15,197 - octoprint.events - DEBUG - Sending action to <function Server.run..on_settings_update at 0x723dd348>
2022-02-25 19:44:15,198 - octoprint.events - DEBUG - Sending action to <bound method PrinterStateConnection._onEvent of <octoprint.server.util.sockjs.PrinterStateConnection object at 0x6aed62d0>>
2022-02-25 19:44:15,199 - octoprint.plugin - DEBUG - Calling on_event on action_command_notification
2022-02-25 19:44:15,200 - octoprint.plugin - DEBUG - Calling on_event on action_command_prompt
2022-02-25 19:44:15,200 - octoprint.plugin - DEBUG - Calling on_event on announcements
2022-02-25 19:44:15,200 - octoprint.plugin - DEBUG - Calling on_event on file_check
2022-02-25 19:44:15,200 - octoprint.plugin - DEBUG - Calling on_event on firmware_check
2022-02-25 19:44:15,201 - octoprint.plugin - DEBUG - Calling on_event on pluginmanager
2022-02-25 19:44:15,201 - octoprint.plugin - DEBUG - Calling on_event on softwareupdate
2022-02-25 19:44:15,201 - octoprint.plugin - DEBUG - Calling on_event on tracking
2022-02-25 19:45:23,075 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2022-02-25 19:45:43,150 - octoprint.plugins.errortracking - INFO - Initialized error tracking
2022-02-25 19:45:43,615 - octoprint.events.fire - DEBUG - Firing event: SettingsUpdated (Payload: {'config_hash': '8bb8e171bb170c50d38330434319eae2', 'effective_hash': '643bd7407e09b794a7c68b2336182f50'})
2022-02-25 19:45:43,615 - octoprint.events - DEBUG - Sending action to <function Server.run..on_settings_update at 0x723dd348>
2022-02-25 19:45:43,616 - octoprint.events - DEBUG - Sending action to <bound method PrinterStateConnection._onEvent of <octoprint.server.util.sockjs.PrinterStateConnection object at 0x6aed62d0>>
2022-02-25 19:45:43,618 - octoprint.plugin - DEBUG - Calling on_event on action_command_notification
2022-02-25 19:45:43,618 - octoprint.plugin - DEBUG - Calling on_event on action_command_prompt
2022-02-25 19:45:43,619 - octoprint.plugin - DEBUG - Calling on_event on announcements
2022-02-25 19:45:43,619 - octoprint.plugin - DEBUG - Calling on_event on file_check
2022-02-25 19:45:43,619 - octoprint.plugin - DEBUG - Calling on_event on firmware_check
2022-02-25 19:45:43,619 - octoprint.plugin - DEBUG - Calling on_event on pluginmanager
2022-02-25 19:45:43,620 - octoprint.plugin - DEBUG - Calling on_event on softwareupdate
2022-02-25 19:45:43,621 - octoprint.plugin - DEBUG - Calling on_event on tracking
