No Serial Port found, Neptune 2S, Marlin, Pi Zero 2W
When trying to connect to Neptune 2S I am receiving a “no serial port” error
New cables, fresh flash, power cycling
Yes no change
octoprint-systeminfo-20250109113935.zip (29.5 KB)
Dmesg result
pi@octopi:~ $ dmesg
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 6.1.21-v7+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1642 SMP Mon Apr  3 17:20:52 BST 2023
[    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: Raspberry Pi Zero 2 W Rev 1.0
[    0.000000] random: crng init done
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] Reserved memory: created CMA memory pool at 0x07c00000, size 256 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000000000-0x0000000017ffffff]
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000000000-0x0000000017ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000017ffffff]
[    0.000000] percpu: Embedded 17 pages/cpu s36884 r8192 d24556 u69632
[    0.000000] pcpu-alloc: s36884 r8192 d24556 u69632 alloc=17*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 97440
[    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=Composite-1:720x480@60i smsc95xx.macaddr=B8:27:EB:1A:1C:4C vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000  console=ttyS0,115200 console=tty1 root=PARTUUID=c6d45de9-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=GB
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 108852K/393216K available (10240K kernel code, 1452K rwdata, 2900K rodata, 1024K init, 613K bss, 22220K reserved, 262144K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] ftrace: allocating 34800 entries in 103 pages
[    0.000000] ftrace: allocated 102 pages with 4 groups
[    0.000000] trace event string verifier disabled
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000]  Rude variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[    0.000001] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[    0.000019] Switching to timer-based delay loop, resolution 52ns
[    0.000382] Console: colour dummy device 80x30
[    0.001012] printk: console [tty1] enabled
[    0.001075] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[    0.001121] pid_max: default: 32768 minimum: 301
[    0.001281] LSM: Security Framework initializing
[    0.001488] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.001530] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.002675] cgroup: Disabling memory control group subsystem
[    0.002931] CPU: Testing write buffer coherency: ok
[    0.003347] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.004210] cblist_init_generic: Setting adjustable number of callback queues.
[    0.004248] cblist_init_generic: Setting shift to 2 and lim to 1.
[    0.004380] cblist_init_generic: Setting shift to 2 and lim to 1.
[    0.004535] Setting up static identity map for 0x100000 - 0x10003c
[    0.004688] rcu: Hierarchical SRCU implementation.
[    0.004713] rcu:     Max phase no-delay instances is 1000.
[    0.005439] smp: Bringing up secondary CPUs ...
[    0.006352] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.007303] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.008162] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.008264] smp: Brought up 1 node, 4 CPUs
[    0.008348] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[    0.008375] CPU: All CPU(s) started in HYP mode.
[    0.008394] CPU: Virtualization extensions available.
[    0.009035] devtmpfs: initialized
[    0.023862] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[    0.024102] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.024157] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.034472] pinctrl core: initialized pinctrl
> Blockquote
subsystem
[    0.035691] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.038830] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.043907] audit: initializing netlink subsys (disabled)
[    0.044155] audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
[    0.044778] thermal_sys: Registered thermal governor 'step_wise'
[    0.045728] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.045782] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.046045] Serial: AMBA PL011 UART driver
[    0.051729] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[    0.070073] raspberrypi-firmware soc:firmware: Attached to firmware from 2023-03-17T10:53:39, variant start_x
[    0.080091] raspberrypi-firmware soc:firmware: Firmware hash is 82f3750a65fadae9a38077e3c2e217ad158c8d54
[    0.122176] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[    0.128272] bcm2835-dma 3f007000.dma: DMA legacy API manager, dmachans=0x1
[    0.129972] SCSI subsystem initialized
[    0.130225] usbcore: registered new interface driver usbfs
[    0.130306] usbcore: registered new interface driver hub
[    0.130375] usbcore: registered new device driver usb
[    0.130608] usb_phy_generic phy: supply vcc not found, using dummy regulator
[    0.130794] usb_phy_generic phy: dummy supplies not allowed for exclusive requests
[    0.131077] pps_core: LinuxPPS API ver. 1 registered
[    0.131103] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.131152] PTP clock support registered
[    2.009605] clocksource: Switched to clocksource arch_sys_counter
[    2.107599] VFS: Disk quotas dquot_6.6.0
[    2.107722] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    2.107897] FS-Cache: Loaded
[    2.108195] CacheFiles: Loaded
[    2.116715] NET: Registered PF_INET protocol family
[    2.116963] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    2.118772] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
[    2.118831] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    2.118876] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[    2.118963] TCP bind hash table entries: 4096 (order: 4, 65536 bytes, linear)
[    2.119152] TCP: Hash tables configured (established 4096 bind 4096)
[    2.119278] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[    2.119332] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[    2.119549] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    2.120134] RPC: Registered named UNIX socket transport module.
[    2.120163] RPC: Registered udp transport module.
[    2.120185] RPC: Registered tcp transport module.
[    2.120206] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    2.121860] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[    2.124994] Initialise system trusted keyrings
[    2.125265] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[    2.134515] zbud: loaded
[    2.136941] NFS: Registering the id_resolver key type
[    2.137000] Key type id_resolver registered
[    2.137023] Key type id_legacy registered
[    2.137160] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    2.137189] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    2.138507] Key type asymmetric registered
[    2.138535] Asymmetric key parser 'x509' registered
[    2.138725] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    2.138760] io scheduler mq-deadline registered
[    2.138784] io scheduler kyber registered
[    2.142093] simple-framebuffer 1eaa9000.framebuffer: framebuffer at 0x1eaa9000, 0x151800 bytes
[    2.142154] simple-framebuffer 1eaa9000.framebuffer: format=a8r8g8b8, mode=720x480x32, linelength=2880
[    2.146880] Console: switching to colour frame buffer device 90x30
[    2.153497] simple-framebuffer 1eaa9000.framebuffer: fb0: simplefb registered!
[    2.160594] bcm2835-rng 3f104000.rng: hwrng registered
[    2.163510] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[    2.169365] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[    2.182673] brd: module loaded
[    2.192660] loop: module loaded
[    2.195836] Loading iSCSI transport class v2.0-870.
[    2.199909] usbcore: registered new interface driver lan78xx
[    2.202566] usbcore: registered new interface driver smsc95xx
[    2.205164] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    2.935826] Core Release: 2.80a
[    2.938349] Setting default values for core params
[    2.940871] Finished setting default values for core params
[    3.143636] Using Buffer DMA mode
[    3.146131] Periodic Transfer Interrupt Enhancement - disabled
[    3.148651] Multiprocessor Interrupt Enhancement - disabled
[    3.151142] OTG VER PARAM: 0, OTG VER FLAG: 0
[    3.153645] Dedicated Tx FIFOs mode
[    3.156877] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = 87d04000 dma = 0xc7d04000 len=9024
[    3.164111] FIQ FSM acceleration enabled for :
               Non-periodic Split Transactions
               Periodic Split Transactions
               High-Speed Isochronous Endpoints
               Interrupt/Control Split Transaction hack enabled
[    3.175361] dwc_otg: Microframe scheduler enabled
[    3.175477] WARN::hcd_init_fiq:457: FIQ on core 1
[    3.179560] WARN::hcd_init_fiq:458: FIQ ASM at 807c4360 length 36
[    3.183544] WARN::hcd_init_fiq:497: MPHI regs_base at 98810000
[    3.187639] dwc_otg 3f980000.usb: DWC OTG Controller
[    3.189800] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[    3.191992] dwc_otg 3f980000.usb: irq 89, io mem 0x00000000
[    3.194156] Init: Port Power? op_state=1
[    3.196256] Init: Power Port (0)
[    3.198511] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[    3.202770] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.205022] usb usb1: Product: DWC OTG Controller
[    3.207237] usb usb1: Manufacturer: Linux 6.1.21-v7+ dwc_otg_hcd
[    3.209491] usb usb1: SerialNumber: 3f980000.usb
[    3.212377] hub 1-0:1.0: USB hub found
[    3.214603] hub 1-0:1.0: 1 port detected
[    3.217330] dwc_otg: FIQ enabled
[    3.217341] dwc_otg: NAK holdoff enabled
[    3.217349] dwc_otg: FIQ split-transaction FSM enabled
[    3.217363] Module dwc_common_port init
[    3.217649] usbcore: registered new interface driver usb-storage
[    3.220019] mousedev: PS/2 mouse device common for all mice
[    3.224419] sdhci: Secure Digital Host Controller Interface driver
[    3.226638] sdhci: Copyright(c) Pierre Ossman
[    3.229087] sdhci-pltfm: SDHCI platform and OF driver helper
[    3.232258] ledtrig-cpu: registered to indicate activity on CPUs
[    3.234760] hid: raw HID events driver (C) Jiri Kosina
[    3.237173] usbcore: registered new interface driver usbhid
[    3.239454] usbhid: USB HID core driver
[    3.241861] bcm2835_vchiq 3f00b840.mailbox: there is not valid maps for state default
[    3.247967] Initializing XFRM netlink socket
[    3.250426] NET: Registered PF_PACKET protocol family
[    3.252846] Key type dns_resolver registered
[    3.255925] Registering SWP/SWPB emulation handler
[    3.258877] registered taskstats version 1
[    3.261193] Loading compiled-in X.509 certificates
[    3.264339] Key type .fscrypt registered
[    3.266576] Key type fscrypt-provisioning registered
[    3.280230] uart-pl011 3f201000.serial: cts_event_workaround enabled
[    3.282584] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 114, base_baud = 0) is a PL011 rev2
[    3.288994] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[    3.291613] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[    3.295233] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
[    3.297643] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
[    3.327362] sdhost: log_buf @ 03915f9c (c7d03000)
[    3.339716] Indeed it is in host mode hprt0 = 00021501
[    3.378746] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[    3.391497] of_cfs_init
[    3.393943] of_cfs_init: OK
[    3.397506] Waiting for root device PARTUUID=c6d45de9-02...
[    3.440957] mmc0: host does not support reading read-only switch, assuming write-enable
[    3.447273] mmc0: new high speed SDHC card at address aaaa
[    3.450513] mmcblk0: mmc0:aaaa SD32G 29.7 GiB
[    3.455704]  mmcblk0: p1 p2
[    3.458572] mmcblk0: mmc0:aaaa SD32G 29.7 GiB (quirks 0x00004000)
[    3.477873] mmc1: new high speed SDIO card at address 0001
[    3.499261] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[    3.501680] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[    3.549639] usb 1-1: new full-speed USB device number 2 using dwc_otg
[    3.552404] EXT4-fs (mmcblk0p2): recovery complete
[    3.552493] Indeed it is in host mode hprt0 = 00021501
[    3.556860] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
[    3.562138] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    3.572087] devtmpfs: mounted
[    3.618760] Freeing unused kernel image (initmem) memory: 1024K
[    3.621702] Run /sbin/init as init process
[    3.624081]   with arguments:
[    3.624088]     /sbin/init
[    3.624096]   with environment:
[    3.624102]     HOME=/
[    3.624109]     TERM=linux
[    3.759640] usb 1-1: device descriptor read/64, error -71
[    3.880010] Indeed it is in host mode hprt0 = 00021501
[    4.089659] usb 1-1: device descriptor read/64, error -71
[    4.112894] systemd[1]: System time before build time, advancing clock.
[    4.209745] Indeed it is in host mode hprt0 = 00021501
[    4.356632] NET: Registered PF_INET6 protocol family
[    4.360725] Segment Routing with IPv6
[    4.363296] In-situ OAM (IOAM) with IPv6
[    4.419709] usb 1-1: new full-speed USB device number 3 using dwc_otg
[    4.422672] Indeed it is in host mode hprt0 = 00021501
[    4.438594] systemd[1]: systemd 247.3-7+rpi1+deb11u1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[    4.453545] systemd[1]: Detected architecture arm.
[    4.473921] systemd[1]: Set hostname to <octopi>.
[    4.629712] usb 1-1: device descriptor read/64, error -71
[    4.750043] Indeed it is in host mode hprt0 = 00021501
[    4.959666] usb 1-1: device descriptor read/64, error -71
[    5.079714] usb usb1-port1: attempt power cycle
[    5.602776] systemd[1]: Queued start job for default target Multi-User System.
[    5.653312] systemd[1]: Created slice system-getty.slice.
[    5.660364] systemd[1]: Created slice system-modprobe.slice.
[    5.667027] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[    5.673389] systemd[1]: Created slice User and Session Slice.
[    5.679320] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[    5.685560] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    5.692732] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    5.701811] systemd[1]: Reached target Local Encrypted Volumes.
[    5.708426] systemd[1]: Reached target Paths.
[    5.714709] systemd[1]: Reached target Slices.
[    5.720863] systemd[1]: Reached target Swap.
[    5.728089] systemd[1]: Listening on Syslog Socket.
[    5.734760] systemd[1]: Listening on fsck to fsckd communication Socket.
[    5.741179] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    5.748365] systemd[1]: Listening on Journal Audit Socket.
[    5.755094] systemd[1]: Listening on Journal Socket (/dev/log).
[    5.762044] systemd[1]: Listening on Journal Socket.
[    5.769814] systemd[1]: Listening on udev Control Socket.
[    5.776274] systemd[1]: Listening on udev Kernel Socket.
[    5.782962] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[    5.830090] systemd[1]: Mounting POSIX Message Queue File System...
[    5.841195] systemd[1]: Mounting RPC Pipe File System...
[    5.853318] systemd[1]: Mounting Kernel Debug File System...
[    5.865237] systemd[1]: Mounting Kernel Trace File System...
[    5.872657] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[    5.888211] systemd[1]: Starting Restore / save the current clock...
[    5.900889] systemd[1]: Starting Set the console keyboard layout...
[    5.913772] systemd[1]: Starting Create list of static device nodes for the current kernel...
[    5.931313] systemd[1]: Starting Load Kernel Module configfs...
[    5.944518] systemd[1]: Starting Load Kernel Module drm...
[    5.957476] systemd[1]: Starting Load Kernel Module fuse...
[    5.971891] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[    5.984758] systemd[1]: Starting File System Check on Root Device...
[    6.004231] systemd[1]: Starting Journal Service...
[    6.022309] systemd[1]: Starting Load Kernel Modules...
[    6.041549] systemd[1]: Starting Coldplug All udev Devices...
[    6.086794] systemd[1]: Mounted POSIX Message Queue File System.
[    6.089138] fuse: init (API version 7.37)
[    6.106769] systemd[1]: Mounted RPC Pipe File System.
[    6.128960] systemd[1]: Mounted Kernel Debug File System.
[    6.139052] systemd[1]: Mounted Kernel Trace File System.
[    6.146533] systemd[1]: Finished Restore / save the current clock.
[    6.154856] systemd[1]: Finished Create list of static device nodes for the current kernel.
[    6.165828] systemd[1]: modprobe@configfs.service: Succeeded.
[    6.169994] systemd[1]: Finished Load Kernel Module configfs.
[    6.177476] systemd[1]: modprobe@fuse.service: Succeeded.
[    6.182052] systemd[1]: Finished Load Kernel Module fuse.
[    6.190492] systemd[1]: Finished Load Kernel Modules.
[    6.204875] systemd[1]: Mounting FUSE Control File System...
[    6.224517] systemd[1]: Mounting Kernel Configuration File System...
[    6.245979] systemd[1]: Started File System Check Daemon to report status.
[    6.276782] systemd[1]: Starting Apply Kernel Variables...
[    6.290124] systemd[1]: modprobe@drm.service: Succeeded.
[    6.294113] systemd[1]: Finished Load Kernel Module drm.
[    6.305477] systemd[1]: Mounted FUSE Control File System.
[    6.312372] systemd[1]: Mounted Kernel Configuration File System.
[    6.364077] systemd[1]: Started Journal Service.
[    6.626433] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
[    6.742679] systemd-journald[135]: Received client request to flush runtime journal.
[    6.789258] systemd-journald[135]: File /var/log/journal/833a2566cd154268b209dbe502b347aa/system.journal corrupted or uncleanly shut down, renaming and replacing.
[    7.956617] mc: Linux media interface: v0.10
[    7.962127] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[    7.964491] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[    7.964526] [vc_sm_connected_init]: start
[    7.965988] [vc_sm_connected_init]: installed successfully
[    8.089751] videodev: Linux video capture interface: v2.00
[    8.095737] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[    8.150948] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[    8.163512] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[    8.179078] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[    8.179880] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[    8.182335] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[    8.182770] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[    8.182811] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[    8.182836] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[    8.182853] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[    8.182869] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[    8.191350] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[    8.191953] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[    8.192463] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[    8.192856] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[    8.192889] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[    8.192911] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[    8.192927] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[    8.192944] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[    8.193162] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[    8.307405] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[    8.375851] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[    8.648886] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[    8.648946] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[    8.659954] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[    8.660009] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[    8.665187] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[    8.665243] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[    8.667722] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[    8.667775] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[    8.703783] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
[    8.703840] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
[    8.741234] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    8.872335] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    8.893702] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[    8.919015] Console: switching to colour dummy device 80x30
[    8.923242] vc4-drm soc:gpu: bound 3f400000.hvs (ops vc4_hvs_ops [vc4])
[    8.941606] Registered IR keymap rc-cec
[    8.941856] rc rc0: vc4-hdmi as /devices/platform/soc/3f902000.hdmi/rc/rc0
[    8.942116] input: vc4-hdmi as /devices/platform/soc/3f902000.hdmi/rc/rc0/input0
[    8.956357] vc4-drm soc:gpu: bound 3f902000.hdmi (ops vc4_hdmi_ops [vc4])
[    8.956994] vc4-drm soc:gpu: bound 3f004000.txp (ops vc4_txp_ops [vc4])
[    8.957502] vc4-drm soc:gpu: bound 3f206000.pixelvalve (ops vc4_crtc_ops [vc4])
[    8.957975] vc4-drm soc:gpu: bound 3f207000.pixelvalve (ops vc4_crtc_ops [vc4])
[    8.958407] vc4-drm soc:gpu: bound 3f807000.pixelvalve (ops vc4_crtc_ops [vc4])
[    8.958752] vc4-drm soc:gpu: bound 3fc00000.v3d (ops vc4_v3d_ops [vc4])
[    9.008458] [drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 0
[    9.018593] vc4-drm soc:gpu: [drm] Cannot find any crtc or sizes
[    9.123830] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
[    9.134373] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43436s-sdio for chip BCM43430/1
[    9.137686] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43436s-sdio.raspberrypi,model-zero-2-w.bin failed with error -2
[    9.142545] usbcore: registered new interface driver brcmfmac
[    9.160949] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43436s-sdio.clm_blob failed with error -2
[    9.335497] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
[    9.336097] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM43430/1 wl0: Jul  5 2022 21:29:56 version 7.45.96.141 (g53ba0094) FWID 01-eef9b3bf es7
[   10.590503] uart-pl011 3f201000.serial: no DMA platform data
[   10.828326] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
[   10.986771] 8021q: 802.1Q VLAN Support v1.8
[   11.197196] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save disabled
[   12.652132] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   15.277775] Bluetooth: Core ver 2.22
[   15.277915] NET: Registered PF_BLUETOOTH protocol family
[   15.277921] Bluetooth: HCI device and connection manager initialized
[   15.278513] Bluetooth: HCI socket layer initialized
[   15.278535] Bluetooth: L2CAP socket layer initialized
[   15.278559] Bluetooth: SCO socket layer initialized
[   15.294886] Bluetooth: HCI UART driver ver 2.3
[   15.294914] Bluetooth: HCI UART protocol H4 registered
[   15.295026] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   15.296027] Bluetooth: HCI UART protocol Broadcom registered
[   15.847058] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   15.847081] Bluetooth: BNEP filters: protocol multicast
[   15.847101] Bluetooth: BNEP socket layer initialized
[   15.857422] Bluetooth: MGMT ver 1.22
[   15.876381] NET: Registered PF_ALG protocol family
[   15.905846] cryptd: max_cpu_qlen set to 1000
[  465.978603] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.wlan0.retrans_time - use net.ipv6.neigh.wlan0.retrans_time_ms instead
pi@octopi:~ $
A couple of things... First, when you post output from your RPi or your printer, please enclose it inside of triple back ticks (use the </> icon to get single back ticks). This will prevent the text from being interpreted by the markdown editor.
Second, please see https://community.octoprint.org/t/no-connection-at-all-with-elegoo-neptune-2/33519 and follow the suggested experiment in that topic. It will provide us both with better information.
Since you are using a Raspberry Pi Zero 2 W Rev 1.0 and I believe the Neptune 2S has a USB 2.0 Type B port, please verify and describe the cabling method. I'd guess you have a micro USB to USB-A adapter and a USB-A to USB-B cable.
Hi there, thank you for your reply.
Apologies for the poor formatting of my original post.
You have made a correct assumption about my cable set up.
I look to have a very similar problem to the thread you’ve linked to. Running your test I get nothing from the printer but plugging in a usb storage device using the micro to USB-a adapter worked fine with logs showing it connect and disconnect. I have tried 2 different cables and 2 different adapters. Looking at your previous post am I just going to have to keep buying cables and hope one of them works?
Edit - forgot to add screen does not illuminate when plugged in to windows pc so do not think backpowering is happening (although it does appear in the device manager just as the other post describes.)
Thank you for reformatting your original post, no apologies necessary. :smiley:
Since the micro to A adapter saw the USB device I assume that it is functioning properly. If you used the USB-A to USB-B cable to connect the printer to a Windows PC then that indicates to me that the cable is OK as well.
That leaves us with the mystery of why the combination of adapter and cable from the RPi Zero 2 doesn't see the printer.
I ran the experiment with my RPi Zero 2W, a micro USB to USB-A adapter, a very long (10m) Active USB cable, and a USB switch connected to my LulzBot TAZ 6.
[  685.586119] dwc_otg_handle_wakeup_detected_intr lxstate = 2
[  686.123968] usb 1-1.3: new full-speed USB device number 6 using dwc_otg
[  686.368194] usb 1-1.3: New USB device found, idVendor=27b1, idProduct=0001, bcdDevice= 0.01
[  686.368227] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=220
[  686.368242] usb 1-1.3: Product: RAMBo
[  686.368254] usb 1-1.3: Manufacturer: UltiMachine (ultimachine.com)
[  686.368265] usb 1-1.3: SerialNumber: 75530313231351F06051
[  686.370526] cdc_acm 1-1.3:1.0: ttyACM0: USB ACM device
The OctoPi system that is normally attached (via the other port on the USB switch) to my TAZ 6 is an RPi 3B.
I am also running a different OS on my RPi Zero 2W, the Raspberry Pi Imager v1.8.5 recommended 32-bit with desktop. If you have a spare micro SD card, you might try that OS to get another data point.
pi@rpizero2:~ $ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 12 (bookworm)"
NAME="Raspbian GNU/Linux"
VERSION_ID="12"
VERSION="12 (bookworm)"
VERSION_CODENAME=bookworm
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
I flashed another microSD card with OctoPi 1.0.0 and it saw my TAZ 6 printer.
I’ll give these a shot tomorrow and report back, thanks so much for your help. Fingers crossed :crossed_fingers:
I cant believe this but it just worked today. But only in a very specific set of circumstances. Only 1 of my cables works (the long one typically) and the printer needed to be on before I powered on the pi.
So sorry to have wasted your time. Will continue to test and update this thread if I discover anything else.
