Not Detecting Printer
The printer will not connect. It worked the first time and now will not connect. I have restarted printer, octoprint, browser and even reinstalled Octoprint. Using Android Octoprint.
Not connecting to printer.
I have restarted printer, octoprint, browser and even reinstalled Octoprint. Also changed timeout settings and wait check box.
Yes
octoprint-systeminfo-20230607175458.zip (34.6 KB)
Octo4a V. 1.2.4, Ender 3 Pro, Mks Robin e3 V1.1, Marlin 2.0.9.5, Edge & Chrome, Windows 10 Pro.
Hello @Chip1 !
Are you running OctoPrint inside a Docker container or inside a VM?
Not that I am aware of.
Just saw, you running Octo4A?
Yes I am. (10 Char min.Bla bla bla)
I recommend to visit the discord OctoPrint-Octo4A channel:
Or the github:
Ok. I do not see an Octo4a anything in Discord.
You found the OctoPrint channel?
The link should just go inside the Octo4A support
Update:
First off the Discord for Octo4A is not helpful to me (No replies to my question).
I did get the printer to connect when I unplug power to phone/OTG cable. As soon as I plug power back in the printer gives error and stops printing.
I saw this article on blocking +pin on usb. Should I block pins on power or data on either pin? Any thoughts?
Article
sure - try it
but just on the usb cable to the printer :wink:
No luck so far. Anyone have any ideas? Maybe the cable I have sucks. What is the recommended brand of cable?
Update for anyone following. It is fixed as of now. The fix was a USB-C hub. Not the two wire splitter that I had. Let's hope it last!
Thanks for all the help.
