The Octotprint webpage is running into a 500 error after a while. And I get Websocket issues in the console log of the server. OctoApp is getting data regardless of an active 500 http error on the octoprint webpage. The webpage itself does so to, a page refresh will let me know if I have run into a 500 http error. Logging isn't saying me a lot to me on this issue.
Shut down plugins. Read various post. Tried to configure websockets in my reverse proxy (I use the reverse proxy of my Synology NAS). Disconnected all USB camera's from my Pi4-2Gb bar the PiCam itself.
Yes. This gave less 500 errors. But not none.
No really. It did get better, but that good be dumb luck. It happens randomly.
Morning! Thanks for your reply. I read somewhere on the forum, can not remember where, that it was not adviced to run the reverse proxy on the same device. Also, I use the reverse proxy for several applications (non-octoprint related) and from efficiency point of view, would like to have just the one reverse proxy.
However, I do use HAProxy on the octoprint instance. This to route traffic from outside to the attached webcams (which are currently not running as a for mentioned issue keeps happening).
What is your advice in my senario?
For completeness I add my reverse proxy test overview from octoprint.
Oh! And what logging would be best to activate to get more information for this issue? All logging I have seen up to now doesn't give me error messages. At most I get a warning message that I think might be related. Like;
2025-01-20 04:38:52,940 - octoprint.server.views - DEBUG - Path / not yet cached (key: ui:_default:http://192.168.2.12/:en), signaling as missing
2025-01-20 08:47:22,189 - octoprint.server.heartbeat - INFO - Server heartbeat <3
If you throw another reverse proxy in front of OctoPrint, you'll also need to configure that as a trusted downstream:
That's also the guide that you should cross check regarding the general configuration of any additional reverse proxies you throw in front of OctoPrint.
With regards to your web socket issues, I see a bunch of authentication errors on the socket:
That sounds like something is getting out of sync somewhere, but I'm unclear on whether that's triggered by OctoApp or something else.
The Internal Server errors sound weird and don't reflect in the log, which makes me wonder if they are actually being generated by OctoPrint and not rather in your additional reverse proxy. Try accessing OctoPrint directly for a bit and see if that solves it.
thank you for your time and response. I have configured host-headers within my Proxy Server that is in front of Octoprint. These are the headers configured;
Is this configuration correct for Octoprint or am I missing something?
I notice my Reverse Proxy Test is giving IP of my (synology) Reverse Proxy as the client IP. Is this an indicator something is off? If so, what could I change to improve the situation?
That not having been done is the reason the client IP is wrong.
IIRC Synology's proxy config correctly, there's an option somewhere under advanced configuration that allows you to enable websocket support.
I don't know if it properly replaces the variables that you've entered into the form there, so I can't say if that will work or not. I run a Synology NAS myself, but their reverse proxy configuration was too much of a black box for me and I've since switched to having my services run behind Traefik in a Docker container.
I do get the client IP address correctly on the local network. From outside the reverse proxy tester still gives the synology reverse proxy as client IP. I will investigate a little further.
Switching to Traefik as main reverse proxy feels like a move that I'll have to make.
Thanks for you time, effort, thoughts and suggestions thus far!
I just started a new print, after that I will make the change.
During the current print, upon switching from one connecting USB webcam stream to the other USB webcam stream (both comming from a C270 camera), I received an 500 error whilest logged in locally (not via proxy, but direct). Also ssh is not available anymore. Printing process is still going and the PiCamera (CSI) is streaming without issues. OctoApp is display telemetry from the printer in realtime (temp etc) thourgh the internet (thus, through the reserve proxy).
Is it a fair assumtion that the issue is related to the USB webcam streaming? My third USB camera, endoscope camera, is also not available (was before the 500 error occurred).
Hm... with nothing in the logs that's a tricky one. I find it somewhat unlikely that the webcam could cause the OctoPrint server to throw an HTTP 500, and I also find it a bit odd that the problem reduced but didn't go away when you went into safe mode.
I also can't find a single call to the web interface in the haproxy.log in your system info bundle that reflects an HTTP 500, so something is definitely being weird here.
The fact that it's also no longer reachable via SSH is an additional thing that doesn't make a ton of sense here. So maybe, just maybe, it's related to the webcam after all, and that's somehow causing the Pi to go crazy, maybe by eating up too many resources. I'm honestly out of ideas right now of what else to try, apart from running the server from an interactive SSH session and try to see if you can reproduce the error there and maybe see something logged to the default output that for some reason never makes it into the log files, but since you said it's happening randomly, that might not even be an option.
And another update. Whilest printing I receive a message that octoprint is not able to resolve octoprint.org. I checked in the settings under the connectivity tab and 1.1.1.1 could be resolved. octoprint.org or other domain names could not.
All 3 USB camera's couldn't be resolved. At the start of the print they could. The Pi Camera (CSI) still gives a crips live images.
As the printjob was almost finished I sliced the next printjob and wanted to upload it, by drag and drop. Webpage reacted with the overlag for drag'n'drop options per screen half. Dropped the gcode, but nothing was being uploaded. Hit F5 and hit another 500 error. On the local network and from outside.
As soon as I have the time I will transfer the camera's to there own camera-streamer instance. I will report back with the results. Until then, I'll try to live with this situation.
