Octopi not detecting any usb devices
Rebooted pi, rebooted pi in safe mode, ssh command lsusb (no USB devices detected other than onboard ethernet)
Logs (octoprint.log, serial.log or output on terminal tab, browser error console ...)
pi@octopi:~ $ lsusb Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
pi@octopi:~ $ ~/.octoprint/logs -bash: /home/pi/.octoprint/logs: Is a directory pi@octopi:~ $ var/log/syslog -bash: var/log/syslog: No such file or directory pi@octopi:~ $ /var/log/syslog -bash: /var/log/syslog: Permission denied pi@octopi:~ $ sud /var/log/syslog -bash: sud: command not found pi@octopi:~ $ sudo /var/log/syslog [sudo] password for pi: sudo: /var/log/syslog: command not found
2019-10-11 13:12:54,365 - octoprint.plugins.excluderegion - INFO - File selected, resetting internal state 2019-10-11 13:12:54,679 - octoprint.plugins.DisplayLayerProgress - INFO - Printing started. Detailed progress started.{'origin': 'local', 'name': u'star_ornament_02(1).gcode', 'file': u'/home/pi/.octoprint/uploads/star_ornament_02(1).gcode', 'owner': 'Ender3', 'path': u'star_ornament_02(1).gcode', 'user': 'Ender3', 'size': 7750183L, 'filename': u'star_ornament_02(1).gcode'} 2019-10-11 13:12:54,691 - octoprint.plugins.excluderegion - INFO - Printing started 2019-10-11 13:12:55,317 - octoprint.plugins.filamentmanager - INFO - Filament used: 0.0 mm (tool0) 2019-10-11 13:12:55,325 - octoprint.plugins.filamentmanager - WARNING - No selected spool for tool0 2019-10-11 13:13:06,010 - octoprint.util.comm - ERROR - Unexpected error while reading from serial port Traceback (most recent call last): File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/comm.py", line 2739, in _readline ret = self._serial.readline() File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/comm.py", line 4844, in readline c = self.read(1) File "/home/pi/oprint/local/lib/python2.7/site-packages/serial/serialposix.py", line 501, in read 'device reports readiness to read but returned no data ' SerialException: device reports readiness to read but returned no data (device disconnected or multiple access on port?) 2019-10-11 13:13:06,037 - octoprint.util.comm - ERROR - Please see https://faq.octoprint.org/serialerror for possible reasons of this. 2019-10-11 13:13:06,053 - octoprint.util.comm - INFO - Changing monitoring state from "Pausing" to "Offline (Error: SerialException: 'device reports readiness to read but returned no data (device disconnected or multiple access on port?)' @ comm.py:_readline:2739)" 2019-10-11 13:14:47,120 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial port" 2019-10-11 13:14:47,453 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually." 2019-10-11 13:14:47,760 - octoprint.plugins.excluderegion - INFO - Printing stopped: event=Error 2019-10-11 13:14:48,916 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial port" 2019-10-11 13:14:49,617 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually." 2019-10-11 13:14:50,557 - octoprint.plugins.excluderegion - INFO - Printing stopped: event=Error 2019-10-11 13:15:11,406 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial port" 2019-10-11 13:15:11,747 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually." 2019-10-11 13:15:12,056 - octoprint.plugins.excluderegion - INFO - Printing stopped: event=Error 2019-10-11 13:15:24,696 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial port" 2019-10-11 13:15:25,038 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually." 2019-10-11 13:15:25,525 - octoprint.plugins.excluderegion - INFO - Printing stopped: event=Error 2019-10-11 13:15:29,328 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial port" 2019-10-11 13:15:29,849 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually." 2019-10-11 13:15:30,175 - octoprint.plugins.excluderegion - INFO - Printing stopped: event=Error 2019-10-11 13:15:54,275 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial port" 2019-10-11 13:15:54,943 - octoprint.plugins.pi_support - WARNING - This Raspberry Pi is reporting problems that might lead to bad performance or errors caused by overheating or insufficient power. !!! UNDERVOLTAGE REPORTED !!! Make sure that the power supply and power cable are capable of supplying enough voltage and current to your Pi. 2019-10-11 13:15:55,018 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually." 2019-10-11 13:15:55,641 - octoprint.plugins.excluderegion - INFO - Printing stopped: event=Error 2019-10-11 13:15:56,603 - octoprint.server.util.flask - INFO - Passively logging in user Ender3 from fe80::db5:85dc:ff2:d531 2019-10-11 13:15:56,790 - octoprint.server.util.sockjs - INFO - Client connection closed: fe80::db5:85dc:ff2:d531 2019-10-11 13:15:59,367 - octoprint.server.util.sockjs - INFO - New connection from client: fe80::db5:85dc:ff2:d531 2019-10-11 13:16:00,292 - octoprint.server.util.flask - INFO - Passively logging in user Ender3 from fe80::db5:85dc:ff2:d531 2019-10-11 13:16:01,285 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.38 2019-10-11 13:16:06,437 - octoprint.server.util.sockjs - INFO - User Ender3 logged in on the socket from client fe80::db5:85dc:ff2:d531 2019-10-11 13:16:08,822 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial port" 2019-10-11 13:16:09,502 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually." 2019-10-11 13:16:10,132 - octoprint.plugins.excluderegion - INFO - Printing stopped: event=Error 2019-10-11 13:16:20,709 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial port" 2019-10-11 13:16:21,385 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually." 2019-10-11 13:16:22,057 - octoprint.plugins.excluderegion - INFO - Printing stopped: event=Error 2019-10-11 13:17:17,623 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial port" 2019-10-11 13:17:18,309 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually." 2019-10-11 13:17:18,924 - octoprint.plugins.excluderegion - INFO - Printing stopped: event=Error 2019-10-11 13:17:25,020 - octoprint.server.api.system - INFO - Performing command for core:reboot: sudo shutdown -r now
Additional information about your setup (OctoPrint version, OctoPi version, printer, firmware, browser, operating system, ...)
I'm not very good with Linux but I can give more information/logs/etc if you let me know the commands needed to check
