Thank you Charlie for the solution. I was editing while you replied... Thanks again.
*We can not see the camera stream on the OctoPrint website at octopi.local.
Curl http://octopi.local:8080/ fails to connect local port 8080 connection refused.
Curl http://192.168.1.53:8080/ fails with the same message.
Curl http://127.0.0,1:8080/ returns an mjpg_streamer test page
Camera model*
We are using an Element 14 Raspberry Pi Camera V2 with Pi Model 3 B.
We installed Octopi V 0.18.0 and updated and fixed broken and rebooted many times.
We can't see the camera on octopi.local:8080/?action=stream with Firefox nor Chrome on Fedora 33.
We are able to ssh into octopi.local, raspi-config pi camera is enabled.
Verified that webcamd is running.
It looks to me like we do not have permision to open port 8080 on octopi.local?
Here is the error message on OcotPrint local webpage.
Webcam stream not loaded
It might not be configured correctly or require authentication. You can change the URL of the stream under "Settings" > "Webcam & Timelapse" > "Webcam" > "Stream URL". If you don't have a webcam you can also just disable webcam support there.
Currently configured stream URL: http://octopi.local:8080/?action=stream
Here is the service webcamd status
pi@octopi:~ $ sudo service webcamd status
β webcamd.service - the OctoPi webcam daemon with the user specified config
Active: active (running) since Sun 2021-02-21 19:59:32 GMT; 18min ago
Process: 440 ExecStart=/root/bin/webcamd (code=exited, status=0/SUCCESS)
Main PID: 469 (mjpg_streamer)
Tasks: 3 (limit: 1939)
ββ469 ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 640x480 -f 10 -d /dev/video0
Feb 21 19:59:31 octopi mjpg_streamer[469]: MJPG-streamer [469]: Format............: JPEG
Feb 21 19:59:31 octopi mjpg_streamer[469]: MJPG-streamer [469]: TV-Norm...........: DEFAULT
Feb 21 19:59:31 octopi mjpg_streamer[469]: MJPG-streamer [469]: www-folder-path......: ./www-octopi/
Feb 21 19:59:31 octopi mjpg_streamer[469]: MJPG-streamer [469]: HTTP TCP port........: 8080
Feb 21 19:59:31 octopi mjpg_streamer[469]: MJPG-streamer [469]: HTTP Listen Address..: 127.0.0.1
Feb 21 19:59:31 octopi mjpg_streamer[469]: MJPG-streamer [469]: username:password....: disabled
Feb 21 19:59:31 octopi mjpg_streamer[469]: MJPG-streamer [469]: commands.............: disabled
Feb 21 19:59:31 octopi mjpg_streamer[469]: MJPG-streamer [469]: starting input plugin input_uvc.so
Feb 21 19:59:31 octopi mjpg_streamer[469]: MJPG-streamer [469]: starting output plugin: output_http.so (ID: 00)
Feb 21 19:59:32 octopi systemd[1]: Started the OctoPi webcam daemon with the user specified config.
sudo apt-get update
reboot
reboot...
sudo iptables -L
sudo iptables --list-rules
both return no rules.
Tried following examples online then realized that mjpeg-streamer already exists in octopi and there was no need to try and reinstall it. Also realized that running mjpeg-streamer again just created another one running. Rebooted many times...
Verified that the mjpeg streamer service was running many times.
stopped webcamd
verified v4l2-ctl --all shows the pi camera on video 0.
verified that raspistill -o cam.jpg writes the image cam.jpg which looked fine. (Note to do this we had to enable raspicam in /boot/config.txt). Just enabling the camera using raspi-config did not work? Did not install a desktop nor any other applications. Used scp to copy the image to my main computer.
Starting up webcamDaemon...
cfg_file: /boot/octopi.txt
camera: auto
usb options: -r 640x480 -f 10
raspi options: -fps 10
Explicitly USB device:
Found video devices:
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
raspi
config file='/boot/octopi.txt':USB device was not set in options, start MJPG-streamer with the first found video device: /dev/video0
<13>Feb 21 19:59:31 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 640x480 -f 10 -d /dev/video0
i: Frames Per Second.: 10
i: Format............: JPEG
o: HTTP Listen Address..: 127.0.0.1
Goodbye...
**syslog from last boot**
Feb 21 20:17:01 octopi CRON[759]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Feb 21 20:25:10 octopi octoprint[361]: 2021-02-21 20:25:10,714 - octoprint.server.util.flask - INFO - Passively logging in user k from ::ffff:xxx.xxx.xxx.xxx
Feb 21 20:25:10 octopi octoprint[361]: 2021-02-21 20:25:10,715 - octoprint.access.users - INFO - Logged in user: k
Feb 21 20:25:10 octopi octoprint[361]: 2021-02-21 20:25:10,849 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:xxx.xxx.xxx.xxx
Feb 21 20:25:11 octopi octoprint[361]: 2021-02-21 20:25:11,217 - octoprint.server.util.flask - INFO - Passively logging in user k from ::ffff:xxx.xxx.xxx.xxx
Feb 21 20:25:11 octopi octoprint[361]: 2021-02-21 20:25:11,218 - octoprint.access.users - INFO - Logged in user: k
Feb 21 20:25:12 octopi octoprint[361]: 2021-02-21 20:25:12,031 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:xxx.xxx.xxx.xxx
Feb 21 20:25:12 octopi octoprint[361]: 2021-02-21 20:25:12,076 - octoprint.server.util.flask - INFO - Passively logging in user k from ::ffff:xxx.xxx.xxx.xxx
Feb 21 20:25:12 octopi octoprint[361]: 2021-02-21 20:25:12,077 - octoprint.access.users - INFO - Logged in user: k
Feb 21 20:25:13 octopi octoprint[361]: 2021-02-21 20:25:13,355 - octoprint.server.util.sockjs - INFO - User kurt logged in on the socket from client ::ffff:xxx.xxx.xxx.xxx
Feb 21 20:29:39 octopi octoprint[361]: 2021-02-21 20:29:39,537 - octoprint.server.heartbeat - INFO - Server heartbeat <3
Feb 21 20:32:31 octopi systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 825 (find)
Feb 21 20:32:31 octopi systemd[1]: Mounting Arbitrary Executable File Formats File System...
Feb 21 20:32:31 octopi systemd[1]: Mounted Arbitrary Executable File Formats File System.
OctoPi version 0.18.0
