Octopi thinks bed is nozzle and nozzle is bed - Makerbot Replicator 2X
Went to try printing a 3DBenchy gcode file using my Makerbot Replicator 2X, but had to stop the print after less than minute as I realised the octopi was heating the wrong elements.
It seems octopi thinks the left nozzle is the bed and the bed is the nozzle so obviously heats both to the wrong temperature.
Is there an easy way to correct this problem?
So could you please share these infos then? Everything else would be just guessing.
BTW: The systeminfo bundle is a zipped file, not just the systeminfo list.
Solved my own problem.
In the GPX plugin settings, under Print Settings, GCode flavor needs to be set to Makerbot.
I incorrectly had it set to RepRap, obviously makes sense not to do this as I was using the Makerbot slicer to create my Gcode file.
All good now, heating the correct elements
Great you found it. So could you please:
