Octopi to printer connection problem
I have octoprint loaded and connected to my network and computer on Rasbery Pi 3.
I get the octoprint screen, but it won't connect to the printer. Monoprice 200V2. I press the connect button but always give the failed message in the setup window. I have looked at forums and they seem to talk a lot about serial ports. dmesg, and other stuff I am sadly ignorant on. I could really use some layman termed guidance.
Try it again with the Malyan/Monoprice Connection Fix plugin :slight_smile:
When you created this new topic, the screen was filled with instructions like Read this first! Remember to provide version numbers, relevant log files and general information about your setup.
Since you ignored those instructions, there is very little we can do to provide assistance. If you provide the additional information, then someone will gladly try and help.
i am trying to update the post with new info but i get a message that says new users can only put 2 links in a post. I'm not sure what that refers too. Any help? thanks
Try it again, I've adjusted your rights.
B-morgan, thanks.
I will try again and hopefully a bit better this time.
I can't connect to our printer from Rasbery Pi3. the connect button on Octoprint leads to the failure statement: Error: Failed to autodetect serial port, please set it manually.
I have Octoprint 1.4.0 running on Octopi 0.17.0 on windows 10
the printer is Monoprice mp select V2
below are the Octoprint.log and Serial.log
if you are able to help thanks. Happy to provide additional info, please just let me know. still very knew to this whole thing.
here is the Octoprint.log
2020-03-25 15:17:00,588 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-03-25 15:17:00,882 - octoprint.server - INFO - --- Log roll over detected ---------------------------------------------------
2020-03-25 15:17:00,885 - octoprint.server - INFO - OctoPrint 1.4.0
2020-03-25 15:17:00,906 - octoprint.plugin.core - INFO - 15 plugin(s) registered with the system:
|  Action Command Prompt Support (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/action_command_prompt
|  Announcement Plugin (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/announcements
|  Anonymous Usage Tracking (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/tracking
|  Application Keys Plugin (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/appkeys
|  Backup & Restore (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/backup
|  Core Wizard (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/corewizard
|  Discovery (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/discovery
|  Error Tracking (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/errortracking
|  Logging (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/logging
|  Login UI (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/loginui
|  Pi Support Plugin (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/pi_support
|  Plugin Manager (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/pluginmanager
|  Printer Safety Check (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/printer_safety_check
|  Software Update (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/softwareupdate
|  Virtual Printer (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/virtual_printer
2020-03-25 15:17:01,000 - octoprint.environment - INFO - Detected environment is Python 2.7.16 under Linux (linux2). Details:
|  hardware:
|      cores: 4
|      freq: 1200.0
|      ram: 917016576
|  os:
|      platform: linux2
|  plugins:
|      pi_support:
|          model: Raspberry Pi 3 Model B Rev 1.2
|          octopi_version: 0.17.0
|  python:
|      pip: 19.3.1
|      version: 2.7.16
|      virtualenv: /home/pi/oprint
2020-03-25 15:17:01,000 - octoprint.server - INFO - ------------------------------------------------------------------------------
2020-03-25 15:17:01,565 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 20}
2020-03-25 15:17:02,491 - octoprint.plugins.tracking - INFO - Sent tracking event pong, payload: {'plugins': u''}
2020-03-25 15:17:03,247 - octoprint.plugins.tracking - INFO - Sent tracking event system_unthrottled, payload: {'throttled_mask': 327680, 'throttled_voltage_now': False, 'throttled_voltage_past': True, 'throttled_overheat_now': False, 'throttled_now': False, 'throttled_past': True, 'throttled_overheat_past': False}
2020-03-25 15:17:05,743 - octoprint.server.preemptive_cache - INFO - ... done in 10.78s
2020-03-25 15:17:48,707 - octoprint.server.util.flask - INFO - Passively logging in user Foust from ::ffff:10.0.0.188
2020-03-25 15:17:48,711 - octoprint.access.users - INFO - Logged in user: Foust
2020-03-25 15:17:50,480 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:10.0.0.188
2020-03-25 15:17:50,665 - octoprint.server.util.flask - INFO - Passively logging in user Foust from ::ffff:10.0.0.188
2020-03-25 15:17:50,667 - octoprint.access.users - INFO - Logged in user: Foust
2020-03-25 15:17:53,049 - octoprint.plugins.announcements - INFO - Loaded channel _important from https://octoprint.org/feeds/important.xml in 0.82s
2020-03-25 15:17:54,147 - octoprint.plugins.announcements - INFO - Loaded channel _releases from https://octoprint.org/feeds/releases.xml in 0.81s
2020-03-25 15:17:55,876 - octoprint.plugins.announcements - INFO - Loaded channel _blog from https://octoprint.org/feeds/octoblog.xml in 0.75s
2020-03-25 15:17:56,641 - octoprint.plugins.announcements - INFO - Loaded channel _plugins from https://plugins.octoprint.org/feed.xml in 0.68s
2020-03-25 15:17:57,598 - octoprint.plugins.announcements - INFO - Loaded channel _octopi from https://octoprint.org/feeds/octopi.xml in 0.82s
2020-03-25 15:17:58,900 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from https://plugins.octoprint.org/plugins.json
2020-03-25 15:18:00,912 - octoprint.plugins.pluginmanager - INFO - Loaded plugin notices data from https://plugins.octoprint.org/notices.json
2020-03-25 15:18:02,816 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-03-25 15:18:06,666 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages/ (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-03-25 15:18:06,668 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-03-25 15:18:06,685 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2020-03-25 15:18:06,826 - octoprint.server.util.sockjs - INFO - User Foust logged in on the socket from client ::ffff:10.0.0.188
2020-03-25 15:22:42,887 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2020-03-25 15:23:26,064 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial port"
2020-03-25 15:23:26,103 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
2020-03-25 15:23:26,866 - octoprint.plugins.tracking - INFO - Sent tracking event commerror_autodetect_port, payload: {u'throttled_now': False, u'throttled_past': True, 'commerror_text': u'Failed to autodetect serial port, please set it manually.', u'throttled_mask': 327680}
here is the serial.log
2020-03-22 17:55:41,465 - Changing monitoring state from "Offline" to "Detecting serial port"
2020-03-22 17:55:41,871 - Serial port list: []
2020-03-22 17:55:41,872 - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
2020-03-22 17:55:42,180 - Failed to autodetect serial port, please set it manually.
2020-03-25 15:23:26,063 - Changing monitoring state from "Offline" to "Detecting serial port"
2020-03-25 15:23:26,101 - Serial port list: []
2020-03-25 15:23:26,102 - Changing monitoring state from "Detecting serial port" to "Error: Failed to autodetect serial port, please set it manually."
2020-03-25 15:23:26,106 - Failed to autodetect serial port, please set it manually.
From the serial.log, the Serial port list is empty and I'm guessing that's not a good thing. Further debugging is going to involve using Linux commands on the RPi. I'll assume you have a Windows desktop machine so the first step is to install PuTTY. Using PuTTY, you will connect to the RPi using the username "Pi" and the password you changed.
Follow the steps in this thread which should help identify how the printer presents itself to the RPi.
Keep track of each step you take in this process and be prepared to provide those steps and as much information as you can capture here so we can help you solve this problem.
