I upgraded the mainboard in my E3P to a Creality 4.2.7 silent board 32 bit. My Octopi does not connect to my printer now.
My terminal in Octoprint states:
Performing autodetection with 0 port/baudrate candidates:
Changing monitoring state from "Detecting serial connection" to "Error: No more candidates to test, and no working port/baudrate combination detected."
Changing monitoring state from "Error: No more candidates to test, and no working port/baudrate combination detected." to "Offline (Error: No more candidates to test, and no working port/baudrate combination detected.)"
I have reflashed the firmware with Marlin 2.0.X.
I have tried setting the Baud rate to 115200.
I have reset my Octopi.
I have tried different USB cables.
I have covered the 5V pin on the USB connector.
Yes and no it did not resolve the problem.
Complete Logs
octoprint.log
, serial.log
or output on terminal tab at a minimum, browser error console if UI issue ... no logs, no support! Not log excerpts, complete logs.)
Terminal Tab:
My setup is:
Raspberry Pi 3B
Ender 3 Pro with 32-bit Creality v4.2.7 silent mainboard
Firmware is Marlin v1.0.1
Octoprint v1.4.2
