Octoprint astopped working
<In 2020 I installed octoprint on an ender 3 stock printer with version1.1.4 board.
This was working flawless with cam and connecting to the printer with serial port scan and baud rate.
I have then renewed the octoprint when new came and also changed the printer board to version v2.4.7 with no issues coming up.
BUT today I put in a new server config 2020-12-02-octopi-buster-armhf-lite-0.18.0 and this was the end of the joy the octoprint cannot find the serial port as it could before so I am lost.
I bet there are more people than me facing this problem.
Any help out there so I can use octoprint with my creality v 2.4.7 board
Best regards Jorn Johanesson the stupid Dane!-- ~~~~~ Filling this out properly makes it WAY more likely to get help quickly ~~~~~ -->
really
Closing this one because you already posted the issue in another thread.
Opened again - we will stick to this topic :wink:
  • found out that octoprint is not able to scan the serial ports on a creality v 2.4.7 board so the only option is auto That does not work on this printerboard.
here is the systeminfo bundle:
browser.user_agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/91.0.4472.164 Safari/537.36
connectivity.enabled: true
connectivity.online: true
env.hardware.cores: 4
env.hardware.freq: 1500
env.hardware.ram: 3959975936
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.model: Raspberry Pi 4 Model B Rev 1.2
env.python.pip: 20.3.3
env.python.version: 3.7.3
env.python.virtualenv: true
octoprint.safe_mode: false
octoprint.version: 1.6.1
No, that is not the systeminfo bundle, that is just the systeminfo.
The systeminfo bundle is a zipped file.
You find it below the system info.
grafik
octoprint-systeminfo-20210724132831.zip (15.8 KB)
so it comes here the sysgtem bundle
I am afraid that I cannot get help here because it is an octoprint programming issue to find the serial port on the creality v2.4.7 printer board. So I have decided to get back to the creality v1.1.4 printer board where the serial port could be found and the octoprint server was working without problems.
Plan goes:
Install the creality v1.1.4
After finding the serial port and baud rate and see the octoprint server working I will then reinstall the creality v 2.4.7 motherboard but definitely keep the installed octoprint server and then just update when asked. The server configuration with cam and port/baud will be kept
This was working until I installed a total new octoprint server.
I am sure this will solve my problem
Thank you for your attention
