On fresh install the octoprint boot is stuck in trying to load the webcam daemon (which I dont wish to install).
It continuesly prints the following lines:
Started the OctoPi webcam daemon with the user specified...
Stopped the OctoPi webcam daemon with the user specified...
Google for others with similar problems, but only solution that I found requires a working console.
No, I have no access to console since the boot wont finish
It would be nice if it was possible to install a version with Raspberry Pi Imager without that bug.
So currently everyone without camera will be stuck in the boot-loop without beeing able to access the console.
You should be able to find the nightly builds as well in the RPi imager.
I don't think everyone is stuck in a boot loop as we would have had a lot more bug reports/issues. As far as I knew it didn't stop the console from working, it just continually restarts in the background.
Unfortunatly I cant do anything tough
but nightly build is a good idea. Thank you.
I discovered that my wlan usb stick isnt working for some reason. Maybe if it would be working the server would be still up and running and most of the people dont realise that the console is blocked. That would explain why there are no or only some complains.
