Every new cable works once or twice, then stops working completely. Printer won't connect directly to my computer or to the raspberry pi with any cable I've used.
Swap cables, test pi usb ports
yes, no
Complete Logs
octoprint.log
, serial.log
or output on terminal tab at a minimum, browser error console if UI issue ... no logs, no support! Not log excerpts, complete logs.)
I will provide logs if you need but all it says is cannot detect serial port so I doubt any helpful information will be there
octoprint 1.5.2, ender 3 base software
