Octoprint can’t connect to ender 3
Octoprint worked perfectly on my brand new ender 3 v2 neo. After a few week I decided to install the klipper plugin. With the installation I wasn’t able to update the firmware. When I inserted the sdcart with the klipper.bin file, the file didn’t change for a cur file.
I decided to clear my PI and download octoprint
Again. Now octoprint cant connect to my printer
I tried new usb cable and reinstalled octoprint.
When I directly connect my laptop to my printer cura slicer, my printer is also not connected.
I tried to
Yes
I tried, but it didn’t solve the problem
Hello @Dikke_Gerrie !
Please:
Send your SystemInfo Bundle. At the surface it looks like you installed the klipper firmware on your printer. To get things working again, you will have to get things set up to work with Klipper. We maybe able to point you in the right direction by reviewing your logs. Click on the blue link for the bundle to learn how to get what we need to help you.
That came to my mind too.
I'm sorry for my late response,
Here are my logs
octoprint-logs.zip (116.1 KB)
when i use the lsusb command in putty with my printer connected, i get the folowowing infromation:
Bus 001 Device 004: ID 1a86:7523 QinHeng Electronics CH340 serial converter
Bus 001 Device 003: ID 0424:ec00 Microchip Technology, Inc. (formerly SMSC) SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Microchip Technology, Inc. (formerly SMSC) SMC9514 Hub
when i unplug the usb on the printer side, i get the following information:
whenever i try to connect to the printer i get this message
It's hard to say if you have successfully flashed your printer with klipper firmware.
At the moment we could assume that you have klipper installed and you could setup your OctoPrint instance to work with Klipper. If we are wrong and you have only partly updated your printer, it would waste a lot of time and effort. I think it would be better if you went back to using Marlin to get things in a good state.
Do you have a backup of the firmware that was installed before you tried to update to klipper?
If you do, you should restore that firmware.
If not, you could just identify a marlin build that is for your printer and try that. Again.. it would get you to a state where you can connect directly to your printer from OctoPrint.
If you have issues with your Klipper install, you should reach out for the Klipper forum:
thank you very much! this solved the problem for me.
