When uploading gcode locally to my octoprint that is connected to my Geeetech A20M at random times the print will shift. Even if I rerun the same print, it has a chance to shift. It doesn't shift at the same layer and it has only shifted once per random print.
I have tested just using the SD card and bypassing Octoprint. Doing so provides flawless prints so I have indeed localized the issue to being with Octoprint and not my hardware.
Logs (octoprint.log, serial.log or output on terminal tab, browser error console ...)
Additional information about your setup (OctoPrint version, OctoPi version, printer, firmware, browser, operating system, ...)
OctoPrint: 1.3.11
Octopi: 0.15.1
Printer: Geeetech A20M
Firmware: Marlin
Browser: Chrome
OS: Windows 10 pro
Hello @Meierme176!
Have you tried the safemode?
Also the serial.log would be quite handy.
Do you use marlin 2.0? I'm asking because layer shifts are a known bug in marlin 2.0 and sometimes even on 1.1.9. Most of the time idex printers are affected.
Sorry, I would have provided that but im not actually sure how
I will check as soon as I get home. If I am, should I try to install an older version or do I have to wait until a fix comes along?
Well first I would check safemode as @Ewald_Ikemann suggested.
Then we should check your logs. You can find help to serial.log and logs in general by clicking on the blue words.
If you didn't modify your printer you should be on 1.1.9 or 1.1.X (which is very close to .9)
here you find your latest official geeetech firmware https://github.com/Geeetech3D/Prusa_I3_3Dprinter/tree/master/A20M_Marlin-1.1.x12864
I also experienced layer shifting. It happened after I started having wifi issues.
2019-09-07 02:32:57,543 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-09-07 02:32:57,547 - octoprint.server - INFO - --- Log roll over detected ---------------------------------------------------
2019-09-07 02:32:57,548 - octoprint.server - INFO - OctoPrint 1.3.9
2019-09-07 02:32:57,551 - octoprint.plugin.core - INFO - 13 plugin(s) registered with the system:
| Action Command Prompt Support (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/action_command_prompt
| Announcement Plugin (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/announcements
| Core Wizard (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/corewizard
| CuraEngine (<= 15.04) (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/cura
| Discovery (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/discovery
| Logging (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/logging
| OctoPi Support Plugin (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/octopi_support
| Plugin Manager (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/pluginmanager
| Printer Safety Check (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/printer_safety_check
| Rewrite wait to busy = /home/pi/.octoprint/plugins/rewrite_wait_to_busy.py
| Software Update (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/softwareupdate
| Strip M110 Parameters = /home/pi/.octoprint/plugins/strip_m110_parameter.py
| Virtual Printer (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/virtual_printer
2019-09-07 02:32:57,578 - octoprint.environment - INFO - Detected environment is Python 2.7.13 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1200.0
| ram: 918192128
| os:
| platform: linux2
| plugins:
| octopi_support:
| model: 3B
| revision: a02082
| version: 0.15.1
| python:
| pip: 9.0.3
| version: 2.7.13
| virtualenv: /home/pi/oprint
2019-09-07 02:32:57,579 - octoprint.server - INFO - ------------------------------------------------------------------------------
2019-09-07 17:02:57,683 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-09-07 17:17:57,685 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-09-07 17:32:57,688 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-09-07 17:39:11,575 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Pausing"
2019-09-07 17:39:11,581 - octoprint.filemanager.analysis - INFO - Starting analysis of local:Crystalography/BD_Dazzling_Juttuli-Kasi_slow.gcode
2019-09-07 17:39:11,604 - octoprint.filemanager.analysis - INFO - Invoking analysis command: /home/pi/oprint/bin/python2 -m octoprint analysis gcode --speed-x=6000 --speed-y=6000 --max-t=10 --throttle=0.0 --throttle-lines=100 --offset 0.03 0.03 /home/pi/.octoprint/uploads/Crystalography/BD_Dazzling_Juttuli-Kasi_slow.gcode
2019-09-07 17:39:12,074 - octoprint.util.comm - INFO - Changing monitoring state from "Pausing" to "Paused"
2019-09-07 17:39:44,793 - octoprint.util.comm - INFO - Changing monitoring state from "Paused" to "Resuming"
2019-09-07 17:39:44,824 - octoprint.util.comm - INFO - Changing monitoring state from "Resuming" to "Printing"
2019-09-07 17:45:40,186 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Cancelling"
2019-09-07 17:45:40,197 - octoprint.filemanager.analysis - INFO - Starting analysis of local:Crystalography/BD_Dazzling_Juttuli-Kasi_slow.gcode
2019-09-07 17:45:40,206 - octoprint.filemanager.analysis - INFO - Invoking analysis command: /home/pi/oprint/bin/python2 -m octoprint analysis gcode --speed-x=6000 --speed-y=6000 --max-t=10 --throttle=0.0 --throttle-lines=100 --offset 0.03 0.03 /home/pi/.octoprint/uploads/Crystalography/BD_Dazzling_Juttuli-Kasi_slow.gcode
2019-09-07 17:45:40,466 - octoprint.util.comm - INFO - Changing monitoring state from "Cancelling" to "Operational"
2019-09-07 17:47:57,690 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-09-07 18:02:57,695 - octoprint.server.heartbeat - INFO - Server heartbeat <3
On my PC, I started experiencing another possibly unrelated issue. I could connect to Google, and run searches, but no other websites had connectivity. I restarted my computer and saw that Windows 10 was demanding another update (I've had the web problem in the past and Windows 10 requiring an update is a common theme). I'll try running the print again in safe mode and I'll let you know if I experience it again.
I tried adding the serial log, but I couldn't find %APPDATA%\OctoPrint\logs on my PC. I'm guessing because I need to look for it on the Pi itself, and not my PC??? Let me know if / how I can add more data. I would have pulled the terminal log, but I didn't think of it at the time.
Recv: ok T:21.6 /0.0 B:22.8 /0.0 T0:21.6 /0.0 T1:21.7 /0.0 @:0 B@:0
Send: M105
Recv: ok T:21.7 /0.0 B:23.1 /0.0 T0:21.7 /0.0 T1:21.6 /0.0 @:0 B@:0
Recv: ok T:21.2 /0.0 B:22.4 /0.0 T0:21.2 /0.0 T1:21.3 /0.0 @:0 B@:0
Send: M105
Recv: ok T:21.1 /0.0 B:22.3 /0.0 T0:21.1 /0.0 T1:21.1 /0.0 @:0 B@:0
Send: M105
Recv: ok T:21.2 /0.0 B:22.5 /0.0 T0:21.2 /0.0 T1:21.3 /0.0 @:0 B@:0
Send: M105
Recv: ok T:21.3 /0.0 B:22.4 /0.0 T0:21.3 /0.0 T1:21.3 /0.0 @:0 B@:0
Send: M105
Send: M105
Recv: ok T:21.2 /0.0 B:22.5 /0.0 T0:21.2 /0.0 T1:21.4 /0.0 @:0 B@:0
Send: M105
Recv: ok T:21.3 /0.0 B:22.5 /0.0 T0:21.3 /0.0 T1:21.3 /0.0 @:0 B@:0
Send: M105
Send: M105
Recv: ok T:21.1 /0.0 B:22.4 /0.0 T0:21.1 /0.0 T1:21.4 /0.0 @:0 B@:0
Send: M105
Send: M105
Send: M105
Recv: ok T:21.2 /0.0 B:22.3 /0.0 T0:21.2 /0.0 T1:21.4 /0.0 @:0 B@:0
Send: M105
Send: M105
Send: M105
Recv: ok T:21.1 /0.0 B:22.3 /0.0 T0:21.1 /0.0 T1:21.3 /0.0 @:0 B@:0
Send: M105
Recv: ok T:21.3 /0.0 B:22.5 /0.0 T0:21.3 /0.0 T1:21.2 /0.0 @:0 B@:0
Send: M105
Recv: ok T:21.1 /0.0 B:22.5 /0.0 T0:21.1 /0.0 T1:21.3 /0.0 @:0 B@:0
Send: M105
Recv: ok T:21.2 /0.0 B:22.4 /0.0 T0:21.2 /0.0 T1:21.4 /0.0 @:0 B@:0
Send: M105
Send: M105
Recv: ok T:21.2 /0.0 B:22.3 /0.0 T0:21.2 /0.0 T1:21.3 /0.0 @:0 B@:0
Send: M105
Recv: ok T:21.3 /0.0 B:22.3 /0.0 T0:21.3 /0.0 T1:21.3 /0.0 @:0 B@:0
Send: M105
Recv: ok T:21.2 /0.0 B:22.4 /0.0 T0:21.2 /0.0 T1:21.2 /0.0 @:0 B@:0
Send: M105
Send: M105
Recv: ok T:21.3 /0.0 B:22.4 /0.0 T0:21.3 /0.0 T1:21.1 /0.0 @:0 B@:0
Send: M105
Send: M105
Send: M105
Recv: ok T:21.3 /0.0 B:22.4 /0.0 T0:21.3 /0.0 T1:21.2 /0.0 @:0 B@:0
Send: M105
Send: M105
Send: M105
Recv: ok T:21.1 /0.0 B:22.4 /0.0 T0:21.1 /0.0 T1:21.2 /0.0 @:0 B@:0
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Recv: ok T:21.1 /0.0 B:22.5 /0.0 T0:21.1 /0.0 T1:21.2 /0.0 @:0 B@:0
Send: M105
Send: M105
Send: M105
Recv: ok T:21.3 /0.0 B:22.3 /0.0 T0:21.3 /0.0 T1:21.4 /0.0 @:0 B@:0
Send: M105
Recv: ok T:21.1 /0.0 B:22.4 /0.0 T0:21.1 /0.0 T1:21.3 /0.0 @:0 B@:0
Send: M105
Recv: ok T:21.3 /0.0 B:22.3 /0.0 T0:21.3 /0.0 T1:21.1 /0.0 @:0 B@:0
Send: M105
Recv: ok T:21.2 /0.0 B:22.2 /0.0 T0:21.2 /0.0 T1:21.3 /0.0 @:0 B@:0
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Recv: ok T:21.3 /0.0 B:22.4 /0.0 T0:21.3 /0.0 T1:21.4 /0.0 @:0 B@:0
Send: M105
Send: M105
Send: M105
Recv: ok T:21.1 /0.0 B:22.2 /0.0 T0:21.1 /0.0 T1:21.2 /0.0 @:0 B@:0
Send: M105
Send: M105
Send: M105
Recv: ok T:21.2 /0.0 B:22.5 /0.0 T0:21.2 /0.0 T1:21.2 /0.0 @:0 B@:0
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Recv: ok T:21.2 /0.0 B:22.3 /0.0 T0:21.2 /0.0 T1:21.2 /0.0 @:0 B@:0
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Recv: ok T:21.2 /0.0 B:22.2 /0.0 T0:21.2 /0.0 T1:21.1 /0.0 @:0 B@:0
Send: M105
Recv: ok T:21.2 /0.0 B:22.2 /0.0 T0:21.2 /0.0 T1:21.2 /0.0 @:0 B@:0
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Recv: ok T:21.1 /0.0 B:22.3 /0.0 T0:21.1 /0.0 T1:21.2 /0.0 @:0 B@:0
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Recv: ok T:21.2 /0.0 B:22.4 /0.0 T0:21.2 /0.0 T1:21.1 /0.0 @:0 B@:0
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Recv: ok T:21.1 /0.0 B:22.4 /0.0 T0:21.1 /0.0 T1:21.1 /0.0 @:0 B@:0
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Recv: ok T:21.1 /0.0 B:22.2 /0.0 T0:21.1 /0.0 T1:21.1 /0.0 @:0 B@:0
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Recv: ok T:21.0 /0.0 B:22.2 /0.0 T0:21.0 /0.0 T1:21.1 /0.0 @:0 B@:0
Send: M105
Recv: ok T:21.1 /0.0 B:22.1 /0.0 T0:21.1 /0.0 T1:21.1 /0.0 @:0 B@:0
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Recv: ok T:21.2 /0.0 B:22.3 /0.0 T0:21.2 /0.0 T1:21.1 /0.0 @:0 B@:0
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Recv: ok T:20.9 /0.0 B:22.3 /0.0 T0:20.9 /0.0 T1:21.3 /0.0 @:0 B@:0
Send: M105
Recv: ok T:21.0 /0.0 B:22.2 /0.0 T0:21.0 /0.0 T1:21.2 /0.0 @:0 B@:0
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Recv: ok T:21.1 /0.0 B:22.1 /0.0 T0:21.1 /0.0 T1:21.2 /0.0 @:0 B@:0
Send: M105
Send: M105
Send: M105
Recv: ok T:21.0 /0.0 B:22.3 /0.0 T0:21.0 /0.0 T1:21.1 /0.0 @:0 B@:0
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Recv: ok T:21.0 /0.0 B:22.1 /0.0 T0:21.0 /0.0 T1:21.1 /0.0 @:0 B@:0
Send: M105
Send: M105
Send: M105
Recv: ok T:21.0 /0.0 B:22.4 /0.0 T0:21.0 /0.0 T1:21.1 /0.0 @:0 B@:0
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Recv: ok T:21.0 /0.0 B:22.1 /0.0 T0:21.0 /0.0 T1:21.0 /0.0 @:0 B@:0
Send: M105
Recv: ok T:21.0 /0.0 B:22.0 /0.0 T0:21.0 /0.0 T1:21.0 /0.0 @:0 B@:0
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
