Octoprint Communication Erros
Communication error
There was a communication error while talking to your printer. Please consult the terminal output and octoprint.log for details. Error: Printer keeps requesting line 19 again and again, communication stuck
Reboot Octorpint and checked all connections
no
no
This is my Terminal Output
Recv: echo:busy: processing
Recv:  T:199.99 /200.00 (436.12) B:59.25 /60.00 (3442.38) @:42 B@:127 W:8
Recv:  T:200.00 /200.00 (436.00) B:59.33 /60.00 (3440.81) @:42 B@:127
Recv:  T:200.00 /200.00 (436.00) B:59.34 /60.00 (3440.75) @:42 B@:127 W:7
Recv:  T:200.03 /200.00 (435.81) B:59.52 /60.00 (3437.13) @:41 B@:122 W:6
Recv:  T:199.98 /200.00 (436.19) B:59.63 /60.00 (3435.13) @:42 B@:115
Recv:  T:200.01 /200.00 (435.94) B:59.69 /60.00 (3433.88) @:42 B@:109 W:5
Recv:  T:199.99 /200.00 (436.06) B:59.81 /60.00 (3431.63) @:42 B@:104 W:4
Recv:  T:199.99 /200.00 (436.06) B:59.93 /60.00 (3429.31) @:42 B@:96
Recv:  T:199.99 /200.00 (436.06) B:59.94 /60.00 (3429.19) @:42 B@:97 W:3
Recv:  T:199.95 /200.00 (436.44) B:60.06 /60.00 (3426.69) @:43 B@:91 W:2
Recv:  T:199.96 /200.00 (436.37) B:60.14 /60.00 (3425.00) @:43 B@:86
Recv:  T:199.98 /200.00 (436.19) B:60.15 /60.00 (3424.81) @:42 B@:87 W:1
Recv:  T:199.97 /200.00 (436.25) B:60.20 /60.00 (3423.63) @:42 B@:86 W:0
Recv: ok N18 P15 B7
Send: N19 M117 CE3S1P Schrauben (2) Generic PLA lw 0.6mm lh 0.28mm if 10.0% ext1 200C bed 60C.gcode*14
Recv: Error:checksum mismatch, Last Line: 18
Recv: Resend: 19
Recv: ok
Recv: Resend: 19
Recv: ok
Recv:  T:200.02 /200.00 (435.87) B:60.29 /60.00 (3421.81) @:41 B@:78
Recv: Resend: 19
Recv: ok
Recv: Resend: 19
Recv: ok
Recv: Resend: 19
Recv: ok
Recv: Resend: 19
Recv: ok
Recv: Resend: 19
Recv: ok
Recv: Resend: 19
Recv: ok
Recv: Resend: 19
Recv: ok
Recv: Resend: 19
Recv: ok
Recv: Resend: 19
Changing monitoring state from "Printing" to "Error"
Send: M112
Send: N20 M112*19
Send: N21 M104 T0 S0*18
Send: N22 M140 S0*85
Closing down send loop
all up to date and running pi 4B
octoprint.log (454.5 KB)
I recently ran into the same problem when I sent a gcode file with an extremely long filename. It generated the same failures and retries on a checksum error. Shortened the filename and resent it from Cura & it printed fine.
Thanks that worked.
