Thank you!
2018-04-24 04:05:58,871 - octoprint.plugin.core - INFO - Found 11 plugin(s) providing 11 mixin implementations, 5 hook handlers
2018-04-24 04:05:58,965 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2018-04-24 04:05:58,989 - octoprint.server - INFO - Intermediary server started
2018-04-24 04:05:58,990 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /hom
e/pi/.octoprint/plugins and installed plugin packages...
2018-04-24 04:05:59,512 - octoprint.plugin.core - INFO - Found 11 plugin(s) providing 11 mixin implementations, 5 hook handlers
2018-04-24 04:05:59,552 - octoprint.cli.server - ERROR - Uncaught exception
File "/home/pi/oprint/bin/octoprint", line 11, in <module>
sys.exit(main())
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/__init__.py", line 565, in main
octo(args=args, prog_name="octoprint", auto_envvar_prefix="OCTOPRINT")
File "/home/pi/oprint/local/lib/python2.7/site-packages/click/core.py", line 716, in __call__
return self.main(*args, **kwargs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/click/core.py", line 696, in main
rv = self.invoke(ctx)
File "/home/pi/oprint/local/lib/python2.7/site-packages/click/core.py", line 1060, in invoke
return _process_result(sub_ctx.command.invoke(sub_ctx))
File "/home/pi/oprint/local/lib/python2.7/site-packages/click/core.py", line 889, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "/home/pi/oprint/local/lib/python2.7/site-packages/click/core.py", line 534, in invoke
return callback(*args, **kwargs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/click/decorators.py", line 17, in new_func
return f(get_current_context(), *args, **kwargs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/cli/server.py", line 183, in serve_command
ignore_blacklist)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/cli/server.py", line 104, in run_server
octoprint_server.run()
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/server/__init__.py", line 261, in run
storage_managers[octoprint.filemanager.FileDestinations.LOCAL] = octoprint.filemanager.storage.LocalFileStorage(self._settings.getBaseFolder(
"uploads"))
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/settings.py", line 1453, in getBaseFolder
os.makedirs(folder)
File "/home/pi/oprint/lib/python2.7/os.py", line 157, in makedirs
mkdir(name, mode)
OSError: [Errno 13] Permission denied: 'H:\\Google Drive\\3d printer\\Code'
2018-04-24 04:00:51,840 - octoprint.startup - INFO - ******************************************************************************
2018-04-24 04:00:51,842 - octoprint.startup - INFO - Starting OctoPrint 1.3.8
2018-04-24 04:00:51,842 - octoprint.startup - INFO - ******************************************************************************
2018-04-24 04:00:52,958 - octoprint.startup - INFO - We don't appear to be online, not fetching plugin blacklist
2018-04-24 04:00:53,050 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /hom
2018-04-24 04:00:55,339 - py.warnings - WARNING - /home/pi/oprint/local/lib/python2.7/site-packages/octoprint/plugin/core.py:1643: UserWarning: N
o PKG-INFO found for package: octoprint_slic3r
warnings.warn('No PKG-INFO found for package: %s' % self.package_name)
2018-04-24 04:00:55,463 - octoprint.plugin.core - INFO - Found 11 plugin(s) providing 11 mixin implementations, 5 hook handlers
2018-04-24 04:00:55,609 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2018-04-24 04:00:55,656 - octoprint.server - INFO - Intermediary server started
2018-04-24 04:00:55,657 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /hom
2018-04-24 04:00:56,178 - octoprint.plugin.core - INFO - Found 11 plugin(s) providing 11 mixin implementations, 5 hook handlers
2018-04-24 04:00:56,220 - octoprint.cli.server - ERROR - Uncaught exception
sys.exit(main())
ignore_blacklist)
storage_managers[octoprint.filemanager.FileDestinations.LOCAL] = octoprint.filemanager.storage.LocalFileStorage(self._settings.getBaseFolder("uploads"))
os.makedirs(folder)
mkdir(name, mode)
2018-04-24 04:43:34,157 - octoprint.startup - INFO - ******************************************************************************
2018-04-24 04:43:34,158 - octoprint.startup - INFO - Starting OctoPrint 1.3.8
2018-04-24 04:43:34,159 - octoprint.startup - INFO - ******************************************************************************
2018-04-24 04:43:35,324 - octoprint.startup - INFO - We don't appear to be online, not fetching plugin blacklist
2018-04-24 04:43:35,398 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages.
2018-04-24 04:43:37,625 - py.warnings - WARNING - /home/pi/oprint/local/lib/python2.7/site-packages/octoprint/plugin/core.py:1643: UserWarning: No PKG-INFO found for package: octoprint_slic3r
2018-04-24 04:43:37,711 - octoprint.plugin.core - INFO - Found 11 plugin(s) providing 11 mixin implementations, 5 hook handlers
2018-04-24 04:43:37,924 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2018-04-24 04:43:37,977 - octoprint.server - INFO - Intermediary server started
2018-04-24 04:43:37,977 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages.
2018-04-24 04:43:38,496 - octoprint.plugin.core - INFO - Found 11 plugin(s) providing 11 mixin implementations, 5 hook handlers
2018-04-24 04:43:38,537 - octoprint.cli.server - ERROR - Uncaught exception
sys.exit(main())
ignore_blacklist)
os.makedirs(folder)
mkdir(name, mode)
2018-04-24 23:09:46,960 - octoprint.startup - INFO - ******************************************************************************
2018-04-24 23:09:46,961 - octoprint.startup - INFO - Starting OctoPrint 1.3.8
2018-04-24 23:09:46,962 - octoprint.startup - INFO - ******************************************************************************
2018-04-24 23:09:48,077 - octoprint.startup - INFO - We don't appear to be online, not fetching plugin blacklist
2018-04-24 23:09:48,171 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2018-04-24 23:09:50,463 - py.warnings - WARNING - /home/pi/oprint/local/lib/python2.7/site-packages/octoprint/plugin/core.py:1643: UserWarning: No PKG-INFO found for package: octoprint_slic3r
2018-04-24 23:09:50,563 - octoprint.plugin.core - INFO - Found 11 plugin(s) providing 11 mixin implementations, 5 hook handlers
2018-04-24 23:09:50,687 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2018-04-24 23:09:50,737 - octoprint.server - INFO - Intermediary server started
2018-04-24 23:09:50,738 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2018-04-24 23:09:51,251 - octoprint.plugin.core - INFO - Found 11 plugin(s) providing 11 mixin implementations, 5 hook handlers
2018-04-24 23:09:51,293 - octoprint.cli.server - ERROR - Uncaught exception
sys.exit(main())
ignore_blacklist)
os.makedirs(folder)
mkdir(name, mode)
2018-04-25 04:08:37,543 - octoprint.startup - INFO - ******************************************************************************
2018-04-25 04:08:37,543 - octoprint.startup - INFO - Starting OctoPrint 1.3.8
2018-04-25 04:08:37,544 - octoprint.startup - INFO - ******************************************************************************
2018-04-25 04:08:38,802 - octoprint.util.connectivity_checker - INFO - Connectivity changed from offline to online
2018-04-25 04:08:39,661 - octoprint.startup - INFO - Blacklist processing done
2018-04-25 04:08:39,730 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2018-04-25 04:08:41,261 - py.warnings - WARNING - /home/pi/oprint/local/lib/python2.7/site-packages/octoprint/plugin/core.py:1643: UserWarning: No PKG-INFO found for package: octoprint_slic3r
2018-04-25 04:08:41,335 - octoprint.plugin.core - INFO - Found 11 plugin(s) providing 11 mixin implementations, 5 hook handlers
2018-04-25 04:08:41,428 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2018-04-25 04:08:41,451 - octoprint.server - INFO - Intermediary server started
2018-04-25 04:08:41,452 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2018-04-25 04:08:41,969 - octoprint.plugin.core - INFO - Found 11 plugin(s) providing 11 mixin implementations, 5 hook handlers
2018-04-25 04:08:42,010 - octoprint.cli.server - ERROR - Uncaught exception
sys.exit(main())
ignore_blacklist)
os.makedirs(folder)
mkdir(name, mode)
I would guess part of the problem stems from trying to use a windows 10 network drive as a fileserver..? How would I change this back without re-imaging?
