I try to update the firmware of my SKR 1.4 trought rx/tx connection and usbmount/flash firmware.
I've follow this guide to connect the board to Octoprint.
I've try this solution, this one too to try to mount the sd card.
octoprint.log (495.1 KB)
I can connect OP to my board and control it but I cant mount the sd card to make the firmware update.
OP > Version 1.4.0
Marlin 2.0 settings for a working RX/TX connection Between SKR V1.4 and PI4 with Octoprint.
Marlin serial port selection :
#define SERIAL_PORT 0
#define SERIAL_PORT_2 -1
